RSPAN
Jim Kerr
Level 2
Level 2
Hi All
I have 3 separate access switches (2960XR) with different vlans on them. These 3 switches have layer 2 connectivity to a Cisco 3850-12S switch.
If I set up 3 separate monitor sessions (1 on each of the 3 access switches) and mark the desitination as an RSPAN vlan will it allow me to copy the source traffic from each switch vlan to the one RSPAN vlan (ie aggregating a copy of the traffic from the source vlans to the one destination RSPAN Vlan) ?
Mark Elsen
 - Not exactly : The RSPAN traffic from the source ports or VLANs is copied into the RSPAN VLAN and forwarded over trunk ports carrying the RSPAN VLAN to a destination session monitoring the RSPAN VLAN. Each RSPAN source switch must have either ports or VLANs as RSPAN sources. The destination is always a physical port.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
ok so if i do something like the following would this work ?:
switch1
Monitor session 1 source vlan 10
Monitor session 1 destination remote vlan 100
switch2
Monitor session 1 source vlan 20
Switch3
Monitor session 1 source vlan 30
Switch4
Vlan 100
Name RSPANvlan
Remote-span
Monitor session 1 destination interface gix/x/x
Make you VLAN 100 created all switches and allowed in the port-channel or trunk to carry the traffic.
here is reference guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swspan.html
BB
