upgarde and upload switch with tight flash space?
baselzind
Level 6
Level 6
i need to upgarde a WS-C3560V2-48PS switch , problem is i want to upload the new image ,  but the available flash space is 11.6 mb and the image is 11.5mb , can i uplaod the new image and leave little flash space left? also i cant delete the old image in case of failback
8 Replies 8
Leo Laohoo
Post the complete output to the command "dir".
SW1#dir
Directory of flash:/
2 drwx 512 Mar 1 1993 00:02:20 +00:00 c3560-ipbasek9-mz.122-55.S E5
498 -rwx 2520 May 17 2015 07:47:07 +00:00 vlan.dat.renamed
499 -rwx 3096 Jun 3 1994 03:33:33 +00:00 multiple-fs
500 -rwx 5777 Mar 1 1993 00:01:17 +00:00 config.text.renamed
501 -rwx 2052 Mar 1 1993 00:01:17 +00:00 private-config.text.rename d
502 -rwx 1934 Jun 3 1994 03:32:59 +00:00 private-config.text
503 -rwx 1096 Mar 1 1993 00:01:01 +00:00 vlan.dat
504 -rwx 8419 Jun 3 1994 03:32:59 +00:00 config.text
27998208 bytes total (12194816 bytes free)
You can follow the below guide : (Step-by-Step Procedure for the 3550 with Use of the CMS Image (.tar File))
with option /overwrite
  • /overwrite
    If you choose to overwrite or replace the current version of software with the newer version, the command syntax is archive download-sw /overwrite tftp://tftp_server_ip/file_name . This document uses this overwrite option.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3550-series-switches/41541-190.html#concept10
Note : take the configuration backup out of the box, do this upgrade in a maintenance window, since switch required a reboot.
Also, suggest to have console access - you can see booting process and upgrade process and capture the logs if any issue. it is easy to diagnosis the issue.
BB
i dont want to overwrite the existing firmware in case i want to rollback , will having small remaining storage when i shift to the new firmware cause any issues?
Post the complete output to the command "dir flash:/c3560-ipbasek9-mz.122-55.SE5".
You need to do some ground and homework to clean up the flash, need to delete unnecessary files to clean.
Even if you clear all the files you still have a space issue, you do not have any other option, other than overwriting install option, also suggested doing these steps preparing an alternative plan in case of any issue so you can use xterm or TFTP to boot with the old image.
BB
Aside from what Balaji said (use the "/overwrite" option), see those files that end with ".rename"? Delete them using the command "del /f /r flash:*.rename". This should free up some space.
Joseph W. Doherty
". . . can i uplaod the new image and leave little flash space left?"
Usually, yes you can. Lack of flash free space is generally only a problem to anything you wish to write later to flash. The most common "unexpected" usage would be a crash dump.
