Upgrade IOS of stack switches
HWangLoyalty_2
We need upgrade IOS for our several stack switches. I would like to use “auto-upgrade” feature. I have two questions about it, I hope you could give me some ideas.
According to Cisco document, auto-upgrade is enable by default. But I found the member switches is disable. Could I enable it (boot auto-copy-sw) on member
switches before I upgrade IOS? Could I active it from master switch to type “boot auto-copy-sw”?
If members of switches is active about “auto-upgrade” , could maser switch copy new IOS to members without any additional commands? If it could, do I need to change boot path manually?
I think "auto-upgrade" is just applied when you have IOS mismatch in the stack. If you want to upgrade IOS of whole stack, the procedure in above link should be good.
Got it! Thank you very much!
