06-12-2013 07:10 AM - edited 03-07-2019 01:51 PM
hello folks - I'm about to perform an upgrade on two Nexus 7010 switches per above. Can I directly upgrade or, do I need to go from version 4 to 5.x and then to 6??
Thank you in advance.
SA7001# dir bootflash:
518 Jan 10 00:37:51 2008 TBM14107479_136878179.lic
15830 Jun 06 11:50:11 2013 dcnm-10.25.32.10-ckpnt.cfg
16384 Jan 09 23:25:25 2008 lost+found/
99698682 Jan 10 00:39:01 2008 n7000-s1-dk9.4.2.2a.bin
100118021 May 06 19:39:17 2010 n7000-s1-dk9.4.2.4.bin
11227501 May 06 20:22:00 2010 n7000-s1-epld.4.2.4.img
23875072 Jan 10 00:39:20 2008 n7000-s1-kickstart.4.2.2a.bin
24727552 May 06 19:42:02 2010 n7000-s1-kickstart.4.2.4.bin
2437120 Jun 08 00:07:36 2010 n7000-s1-kickstart.5.0.2a.bin
4096 Jun 06 11:50:17 2013 vdc_2/
4096 Sep 09 09:10:05 2010 vdc_3/
4096 Jan 10 01:05:28 2008 vdc_4/
Usage for bootflash://sup-local
388067328 bytes used
1421832192 bytes free
1809899520 bytes total
SA7001# dir bootflash://sup-standby/
45011 May 26 16:11:43 2010 SP7001-Production-running-config
15850 Jun 01 11:50:10 2013 dcnm-10.25.32.10-ckpnt.cfg
15593 Oct 05 09:07:19 2010 dcnm-10.25.32.249-ckpnt.cfg
24 Sep 09 20:26:07 2012 lensql
49152 May 06 19:47:00 2010 lost+found/
99698682 Jan 10 00:39:42 2008 n7000-s1-dk9.4.2.2a.bin
11227501 May 06 19:44:19 2010 n7000-s1-epld.4.2.4.img
23875072 Jan 10 00:39:53 2008 n7000-s1-kickstart.4.2.2a.bin
65690 Jun 09 19:59:05 2010 peter
171101971 Feb 18 12:45:00 2011 sa7001.txt
64873 May 28 17:30:45 2010 static
65690 Jun 09 19:58:27 2010 vdc
4096 Jun 01 11:50:16 2013 vdc_2/
4096 Apr 08 11:50:04 2013 vdc_3/
4096 Jan 08 07:37:56 2008 vdc_4/
Usage for bootflash://sup-standby
706633728 bytes used
1103265792 bytes free
SA7001# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
BIOS: version 3.19.0
loader: version N/A
kickstart: version 4.2(4)
system: version 4.2(4)
BIOS compile time: 03/31/09
kickstart image file is: bootflash:/n7000-s1-kickstart.4.2.4.bin
kickstart compile time: 1/5/2010 1:00:00 [02/25/2010 10:22:46]
system image file is: bootflash:/n7000-s1-dk9.4.2.4.bin
system compile time: 1/5/2010 1:00:00 [02/25/2010 11:15:58]
Hardware
cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
Intel(R) Xeon(R) CPU with 8297264 kB of memory.
Processor Board ID JAF1414CJPR
Device name: SA7001
bootflash: 2000880 kB
slot0: 0 kB (expansion flash)
Kernel uptime is 5 day(s), 2 hour(s), 30 minute(s), 29 second(s)
Last reset
Reason: Unknown
System version: 4.2(4)
Service:
plugin
Core Plugin, Ethernet Plugin
CMP (Module 5) ok
CMP Software
CMP BIOS version: 02.01.05
CMP Image version: 4.2(1) [build 4.2(1)]
CMP BIOS compile time: 7/13/2008 19:44:27
CMP Image compile time: 9/25/2009 9:00:00
CMP (Module 6) ok
CMP Software
SA7001# Show module
Mod Ports Module-Type Model Status
1 32 10 Gbps Ethernet Module N7K-M132XP-12 ok
2 48 1000 Mbps Optical Ethernet Modul N7K-M148GS-11 ok
5 0 Supervisor module-1X N7K-SUP1 active *
6 0 Supervisor module-1X N7K-SUP1 ha-standby
10 32 10 Gbps Ethernet Module N7K-M132XP-12 ok
Mod Sw Hw
1 4.2(4) 1.7
2 4.2(4) 1.2
5 4.2(4) 1.6
6 4.2(4) 1.6
10 4.2(4) 1.7
Mod MAC-Address(es) Serial-Num
1 68-ef-bd-d9-21-d4 to 68-ef-bd-d9-21-f8 JAF1414BEBL
2 88-43-e1-d7-66-40 to 88-43-e1-d7-66-74 JAF1405AHNH
5 00-26-98-1e-2d-48 to 00-26-98-1e-2d-50 JAF1414CJPR
6 00-26-98-1e-40-d0 to 00-26-98-1e-40-d8 JAF1414CJRC
10 54-75-d0-0a-5b-14 to 54-75-d0-0a-5b-38 JAF1414CJEM
Mod Online Diag Status
1 Pass
2 Pass
5 Pass
6 Pass
10 Pass
Xbar Ports Module-Type Model Status
1 0 Fabric Module 1 N7K-C7010-FAB-1 ok
2 0 Fabric Module 1 N7K-C7010-FAB-1 ok
3 0 Fabric Module 1 N7K-C7010-FAB-1 ok
Xbar Sw Hw
1 NA 1.1
2 NA 1.1
3 NA 1.1
Xbar MAC-Address(es) Serial-Num
1 NA JAF1411BMFQ
2 NA JAF1412BLJN
3 NA JAF1412BBRG
06-12-2013 08:38 AM
You cant upgrade directly.
Ref
Starting Release | Intermediate Release | Destination Release |
4.2(6), 5.0(3), 5.1(3), or 5.1(5) | 5.2(7)1 | 6.1(4) |
2-
Refer to Table 4 for the nondisruptive upgrade (ISSU) path to, and nondisruptive downgrade (ISSD) path from Cisco NX-OS Release 6.0(x). Releases that are not listed for a particular release train do not support a direct ISSU or ISSD to the current release.
Current Release | Release Train | Releases That Support ISSU to Current Release | Releases That Support ISSD from Current Release |
Cisco NX-OS Release 6.0(4) | 6.0 | 6.0(1), 6.0(2), 6.0(3) | 6.0(1), 6.0(2), 6.0(3) |
5.2 | 5.2(1), 5.2(3a), 5.2(4), 5.2(5), 5.2(7)1 | 5.2(1), 5.2(3a), 5.2(4), 5.2(5), 5.2(7) |
1 Before performing an ISSU to NX-OS Release 6.0(x), see the IPFIB Errors caveat in this section. |
Inayath
*******Plz rate if this info is helpfull.
06-13-2013 03:11 AM
Thank you.
What about EPLD??
Will in need to double upgrade that also? (i.e. version 4 to 5 to 6?)
99698682 Jan 16 18:39:24 2008 n7000-s1-dk9.4.2.2a.bin
100118021 May 06 19:31:00 2010 n7000-s1-dk9.4.2.4.bin
11227501 May 06 19:33:30 2010 n7000-s1-epld.4.2.4.img
23875072 Jan 16 18:39:33 2008 n7000-s1-kickstart.4.2.2a.bin
24727552 May 06 19:34:35 2010 n7000-s1-kickstart.4.2.4.bin
06-13-2013 03:19 AM
Yes thats right.
Inayath
*Plz rate all usefull posts and mark the thread as answered if this has solved your query.
