Upgrading IOS problems1
Jeromy Polachak
Level 3
Level 3
Hello all,
I am not seeing what I am missing and the reason its not loading the IOS.
Router#show version
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(17a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 19-Jun-03 16:35 by pwade
Image text-base: 0x8000808C, data-base: 0x80A14C38
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 41 minutes
System image file is "flash:c2600-i-mz.122-17a.bin"
cisco 2611XM (MPC860P) processor (revision 0x301) with 125952K/5120K bytes of memory.
Processor board ID JAE0825M2P7 (592030231)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
I have three different IOS versions, one that is 13 K, 27, and 32. (cisco 2611XM (MPC860P) processor (revision 0x301) with 125952K/5120K bytes of memory.) I can use any of these right?
The router is giving me this error when im trying to load it.
Router#copy tftp flash
Address or name of remote host [192.168.1.1]?
Source filename [c2600-ipbasek9-mz.124-17a]?
Destination filename [c2600-ipbasek9-mz.124-17a]?
Accessing tftp://192.168.1.1/c2600-ipbasek9-mz.124-17a...
%Error opening tftp://192.168.1.1/c2600-ipbasek9-mz.124-17a (No such file or directory) Router#copy tftp flash
The remote host is my computer IP address right? Address or name of remote host [192.168.1.1]? Which it is.
Then the exact file names that im seeing on my computer (which is correct)
Thank you!
Jeromy
Jeromy
5 Replies 5
Hello
Looks like you are missing a syntax :
Copy tftp flash:
Res
Paul
Kind Regards
Paul
No thats not it, tried the difference and its not working. One thing i figured out so far was i was missing the .bin at the end of the file name. The ip addres of the remote host is of my router not my computer right that was another error i was making. But now im getting this problem.
Router#copy tftp flash:
Address or name of remote host [192.168.1.1]? 192.168.1.10
Source filename [c2600-ipbasek9-mz.124-17a.bin]?
Destination filename [c2600-ipbasek9-mz.124-17a.bin]?
Accessing tftp://192.168.1.10/c2600-ipbasek9-mz.124-17a.bin...
%Error opening tftp://192.168.1.10/c2600-ipbasek9-mz.124-17a.bin (Timed out)
Jeromy
Jeromy
Hello
Okay what are you using for a tftp server?
Sometime they cannot transfer a large file or software FW or AV on your pc is prohibiting the transfer.
If you can setup another switch or router to be a tftp server and try again or disable any software fw and AV on your pc
Res
Paul
Kind Regards
Paul
Im using the ciscokits server, so i don't think thats the problem because i did it prior and had no issues.
Jeromy
Jeromy
I am so smart lol I figured it out. It was saying no directory or file, because the file i was trying to load it was in a different folder then my TFTP server was set up.
Jeromy
Jeromy
