Upper limit to dot1q sub-interfaces on 2600?
steve.dutky
Is there any restriction to the number of FastEthernet dot1q sub-interfaces you can configure on a 2600 series router?
Thanks!
ankbhasi
Hi Steve,
It all depends upon the IDBs (Interface Descriptor Block) on each platform. But in general you will get enough that you can accomodate your requirement easily.
Check this link and it will give you the details or each and every platform
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml#max_no_interfaces
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Steve,
Ankur
~800? Looks like about 750 more than I will ever need.
