11-26-2006 06:45 AM - edited 03-05-2019 01:01 PM
Hi, all!
I got a second-handed WIC-1ENET card for my Cisco 1700. But the card doesn't run. No LED on the card lights when the system boot up. And any ethernet interface has not shown when I enter "show run" command. Why?
How much physical memory does Cisco 1700 with 1 WIC-1ENET need?
Thanks.
Solved! Go to Solution.
11-26-2006 07:10 AM
What version of IOS are you running on your 1700?
Check the compatibility matrix on the main Cisco site to see if your version supports the Ethernet WIC.
How sure are you that the WIC is good? Can its operation be verified in another router?
I believe that some of the older 1700s cannot support an additional Ethernet (only the WAN + one ethernet/fast ethernet).
Good Luck
Scott
11-26-2006 08:39 PM
Whats the exact router model you are having over ther? I have run WIC-1ENET on a Cisco 1751 router withtout any probs.
You can also check out the ios compatibility to the Card in your router.
Do refer the below link for finding out the required ios.
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
11-26-2006 07:10 AM
Good Luck
Scott
11-26-2006 08:39 PM
regds
11-27-2006 06:26 AM
Thanks for your advice, brother.
My routers and switches are all second-handed so that I cannot access your recommended site.
So I used the Solution Finder for Modular Routers.
I upgraded the IOS.
(output omitted)
Verifying checksum... OK (0x9C8A)
4284648 bytes copied in 56.400 secs (76511 bytes/sec)
Router#sh run
Building configuration...
Current configuration : 378 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
interface Ethernet0
no ip address
shutdown
half-duplex
interface FastEthernet0
Router#
(`・ω・?)
11-27-2006 06:09 AM
Thanks for your advice, Scotty.
This made me cry below.
(?・ω・`)#sh diag
Slot 0:
C1720 1FE Mainboard Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.1
PCB Serial Number : JAD0610018A
Part Number : 73-3201-06
Board Revision : A0
Fab Version : 04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 B2 41 06 01 C1 8B 4A 41 44 30 36 31
0x10: 30 30 31 38 41 82 49 0C 81 06 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Unknown
Hardware revision 64.0 Board revision G0
Serial number 0960561920 Part number 130-18710-165
Test history 0x03 RMA number 66-65-48
Connector type PCI
0x20: 04 FF 40 00 39 41 03 00 82 49 16 A5 03 42 41 30
0x30: 80 00 00 00 00 02 02 C1 8B 56 4D 53 30 35 35 30
I will search the minimum IOS version.
11-27-2006 06:30 AM
Thanks to all!
See you again.
