USB to Serial adapter connection
cisco steps
I have a iBook G4. Console cable, and USB to Serial adapter cable. I would like to be able to console into a Cisco router, I am using Zterm as was recommanded early for Hyperterminal. it seems that the connection is there. when I click on the Zterm app I get a blank white screen with
ATE1 V1
OK
any one have any idea how to use this terminal or help get connected
I know that I can use Terminal to telnet into the router, but I need to console in first to set up the basic configuration.
17 Replies 17
You deserve it :-)
Hi! Mohamedmahmoud:
I have the same problem with this usb-serial cable.  I install Prolific driver for windows XP.  I still do not get any thing display in my Tera Term.  The driver is install correctly, displayed in my Driver Manager.  I am running out of idea what will make it work.
Please help!
Thanks!
Grace
usasigcis
in mac open "terminal " under utilities and type "screen /dev/tty.Keyserial"
