Using ACL to restrict VPN access from a Subnet
Kaushik Ray
Hello all
I am trying to restrict VPN access from a couple of subnets on a Cisco Router.
The following is the config I have put in but it still allows VPN to establish. Cisco AnyConnect is being used as a VPN Client
RTR# sh run | section ip access-list extended BlockVPN_CORP
 deny   udp 172.26.20.0 0.0.0.255 any eq isakmp non500-isakmp
 deny   udp 172.26.21.0 0.0.0.255 any eq isakmp non500-isakmp
 deny   tcp 172.26.20.0 0.0.0.255 any eq 500 4500
 deny   tcp 172.26.21.0 0.0.0.255 any eq 500 4500
 deny   udp any 172.26.20.0 0.0.0.255 eq isakmp non500-isakmp
 deny   udp any 172.26.21.0 0.0.0.255 eq isakmp non500-isakmp
 deny   tcp any 172.26.20.0 0.0.0.255 eq 500 4500
 deny   tcp any 172.26.21.0 0.0.0.255 eq 500 4500
 permit ip any any
interface GigabitEthernet0/0.98
 encapsulation dot1Q 98
 ip access-group BlockVPN_CORP in
 ip access-group BlockVPN_CORP out
Can you please advise where I am getting wrong?
John Blakley
Anyconnect may be using 443 to establish VPN. Try adding:
deny   tcp any 172.26.20.0 0.0.0.255 eq 443
deny   tcp any 172.26.21.0 0.0.0.255 eq 443
deny   tcp 172.26.20.0 0.0.0.255 any eq 443
deny   tcp 172.26.21.0 0.0.0.255 any eq 443
Protocol
Cisco AnyConnect Client Port
TLS (SSL)
TCP 443
SSL Redirection
TCP 80 (optional)
DTLS
UDP 443 (optional, but highly recommended)
IPsec/IKEv2
UDP 500, UDP 4500
Obviously, the acl entries are just for example. You'll need to take into account where the vpn traffic is terminating and specify that host. For example:
deny   tcp host <VPN host IP> 172.26.20.0 0.0.0.255 eq 443
deny   tcp host <VPN host IP> 172.26.21.0 0.0.0.255 eq 443
deny   tcp 172.26.20.0 0.0.0.255 host <VPN host IP> eq 443
deny   tcp 172.26.21.0 0.0.0.255 host <VPN host IP> eq 443
If you don't, you'll block normal ssl traffic.
HTH,
John
HTH, John *** Please rate all useful posts ***
