Using minicom to configure Cisco 2960's VLAN - Problem: switch command prompt doesn't appear
msrabie
Hello Everybody,
Given:
- Switch: Cisco 2960
- OS: Centos 7
- Serial port configuration: minicom
- Used Configuration:
     9600 8N2 ,Hardware Control Flow: No,  Software Control Flow: No
- Status: Online
Target:
- Configure a VLAN for the switch.
Problem:
After saving the default configuration using minicom, then running minicom, the switch command doesn't appear!
I would appreciate any help.
Mahmoud
6 Replies 6
Philip D'Ath
It should be:
9600 8N1
What do you mean the "switch" command?
Hi Philip
Thanks for your response.
I meant the command prompt of the switch to be able to interact with it by commands.
It should be:
9600 8N1
In the guide, the stop bits = 2.
Reference
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/hardware/installation/guide/2960_hg/hgcliset.html
Mahmoud
It is wrong.  Use 8N1.
Are you sure you have specified the correct serial port on the machine?
Philip,
Thanks again.
Here are the steps that I did:
1) Get the tty name
[root@lab36inst instructor]# dmesg | grep tty
[    0.000000] console [tty0] enabled
[    0.574378] 00:07: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
2) Save the default configuration of Serial Port Setup with minicom
[root@lab36inst instructor]# minicom -s
    | A -    Serial Device              : /dev/ttyS0
    | C -   Callin Program            :
    | D -  Callout Program           :
    | E -    Bps/Par/Bits               : 9600 8N1
    | F - Hardware Flow Control : Yes
    | G - Software Flow Control  : No
    |    Change which setting?
3) Run minicom. It stuck at the following output without entering to the Switch# prompt as I expect. Moreover, always the status is Offline.
Mahmoud
What kind of serial port is this?  Built in, USB, etc?  I presume you are plugged into the actual console port on the switch - or are you using the newer USB interface?
Try these device names as well.  You need to find a port that is actually online.
/dev/ttyusb0
/dev/ttyusb1
/dev/ttyACM1
I am plugging the console cable directly from the switch to the PC serial port. So, the port is the serial port.
