v-mismatch on H/W catalyst 9300
Sudqi
Hello everybody
I have a problem for stack switches that can't connect, the problem is v-mismatch
noted that the ios version is the same, but my question is:
the system boot version is different, is that the problem cause? and how to solve
also, the H/W version is a mismatch, and how we can solve it?
All stack members must either be in Install or Bundle Mode.  It cannot be both.
Install Mode is the recommended method.
22 Replies 22
Leo Laohoo
"Hardware version" has nothing to do with "v-mismatch".
Post the complete output to the following command:
sh platform
thanks, Leo for your reply, please check the pic that I attached
also, the show platform command is attached
Please provide the output to the command "sh platform" from BOTH switches?
please find the attached show platform for the other switch
it clearly indicates that there is hardware version V03 for one switch and the other is V02
but I don't know how to fix it
Thanks for the output.
NOTE:  HW version has NOTHING TO DO with the issue.  This is a software-related issue -- and I am going to focus on that.
Can I see the complete output to the "sh version" command from both units.
I suspect one is on Install Mode and the other is Bundle Mode.
yes you are right, one is on install mode, and the other on bundle mode
should I make both in install mode?
thanks a lot Leo, I will apply the solution and feedback
Thank you Leo the problem solved after made the two switches on install mode
appreciate your great support
Thanks for the update.
Please mark this thread as "Answered".
its done, thank you
Hello ,
I have two cisco 3650 sw and I want to configure them in installation mode, what is the procedure
Thank you
Please take the time to read the attached file in my previous comment.
marce1000
 - You may try to enable  software auto-upgrade enable in the config (save it) and reboot , check if this helps.
                                        More info :
   https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-5/configuration_guide/stck_mgr_ha/b_165_stck_mgr_ha_9300_cg.pdf
                       (and look for /find auto-upgrade)
 M.
