Vlan 2 not able to ping gateway.
gssagoo22
we are able to ping and access networks from vlan1 to vlan 2 with no issues at all.
I am making some assumptions here -
Your UTM box  is the GW of last resort for your Network (address is 172.16.1.1)
The Core Switch (config you attached) is the default GW for your VLANs/Clients.
You cannot Ping VLAN 2 to UTM and Vice Versa.
If I understand what you are trying to achieve then I believe you will need routes on your UTM box.
ip route 172.17.0.0 255.255.0.0 172.16.1.37
ip route 172.18.0.0 255.255.0.0 172.16.1.37
On your L3 switch - enable IP routing.
16 Replies 16
GRANT3779
Your subject says Vlan 2 is unable to ping GW, but PCs in Vlan 2 can reach PCs in Vlan 1? Did you mistype?
If communication is happening between the VLANs then I suspect the GW is reachable.
Are you talking about Vlan 3 PCs not being able to hit their GW?
nope I did not mistyped anything. communication is happening between Vlan 1 and 2. the only problem is that we are not able to reach the gateway from VLan 2.
our gateway is a UTM box. is there anything need to configure at the gateway level?
Does the gateway have a route for the VLAN 2 network?
on Gateway i have an entry with 172.17.0.0/16 to 172.16.1.1
Where on the network and what device is 172.16.1.1?
Looking at your config you attached I see you have the following -
ip default-gateway 172.16.1.1
On a side note, I do not think you need this command as you are running the switch in Layer 3 mode. If it was Layer 2, then you would need that command.
Do you have a brief topology of the setup?
172.16.1.1 is a UTM device acting as a Gateway..
Have you enabled IP Routing on the Core Switch first of all and then on your Core Switch add
ip route 0.0.0.0 0.0.0.0 172.16.1.1 as chrihussey has already advised?
already done that..
#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.16.1.1 to network 0.0.0.0
C 172.17.0.0/16 is directly connected, Vlan2
C 172.16.0.0/16 is directly connected, Vlan1
S* 0.0.0.0/0 [1/0] via 172.16.1.1
From your Core switch, can you ping the GW sourcing from the 172.16.x.x subnet?
Ping 172.16.1.1 source 172.16.1.37
Am I missing something here, but if the gateway is 172.16.1.1, why does it have a route saying "on Gateway i have an entry with 172.17.0.0/16 to 172.16.1.1".
Grant's earlier post said it should be:
here are the ping result
Mcubecore2#ping
Protocol [ip]:
Target IP address: 172.16.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 172.17.1.30
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 172.16.1.1, timeout is 2 seconds:
Packet sent with a source address of 172.17.1.30
Success rate is 0 percent (0/5)
As stated in my earlier post the switch needs a route pointing to your gateway. The default gateway statement is not sufficient. It also needs IP routing enabled.
A topology might help. Where is the GW plugged into and what is the IP address of the GW?
