VLAN-Based QoS over different Catalyst switches
hectormiranda
I have this scenario:
SW1 -- SW2 -- SW3 -- SW4 -- SW5 -- R1 - Central LAN
SW1, 2, 4 & 5 are Catalyst 3560, SW3 is Catalyst 2950. All Layer-2 capable. VLAN routing is performed in R1 at central location.
Each "--" link is fiber optic Gigabit point to point, some kilometers long.
In every Catalyst switch there's a bunch of different types of traffic injected from some PCs, video cameras and real time signaling machines.
Each type of traffic is contained in its specific VLAN, i.e. there's a VLAN for PCs, a VLAN for cameras and another VLAN for signaling machines.
We need to implement QoS to prioritize these VLANs and to provide them different amounts of bandwidth.
It's my first time with QoS so I decided to simply implement VLAN-Based QoS.
I have tried with some class-maps and policy-maps, but when I try to assign the service-policy input to the SVIs i receive errors regarding invalid police.
Can anybody teach me with a good example how this QoS solution can be accomplished?
Thanks in advance,
Hector Miranda
4 Accepted Solutions
Reza Sharifi
Hello Hector,
Since most of your devices are 3560 switches, here is good place to start with.  It provides config guides with examples:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swqos.html
Reza
andtoth
Level 4
Level 4
Hi Hector,
As the 3560 switches are similar in architecture to the 3750 switches, the following documentation will help you to get started.
Cisco Catalyst 3750 QoS Configuration Examples
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml
Best regards,
Andras
Hi Hector,
Your configuration seems to be correct.
Are you looking for confirmation only or do you experience any specific issues with this config? If so, please share some more details what is the actual problem and what are the symptoms.
The config is indeed correct.
Best regards,
Andras
Hi Hector,
Thanks for the reply. Please don't forget to rate helpful posts and mark this post as answered.
Best regards,
Andras
9 Replies 9
Reza Sharifi
Hello Hector,
Reza
andtoth
Level 4
Level 4
Hi Hector,
Best regards,
Andras
Thank you guys,
I have been reading a lot both documents this last weekend.
I've finally written this model configuration. This switch is a WS-C3560V2-48PS-E, with software version
12.2(50)SE1. This is the spanning-tree root and VTP domain server for the rest of the switches.
These are the existant VLANs and the bandwidth and precedence I want to set to the traffic into each one:
VLAN ID    VLAN NAME     BANDWIDTH    PRECEDENCE
10             IPMux                 16 Mbps                5
20             Cameras              2 Mbps                 7
30             Scada                  6 Mbps                 6
40             Web                    600 Mbps              4
50             Other                   376 Mbps              0
So, I've written the following configuration file:
1) Enable QoS in global configuration mode:
mls qos
2) Create hierarchical policy-maps
policy-map bw376M
description ***************  VLAN 50 Other  ***************
class class-default
  police 376000000 8000 exceed-action drop
policy-map VLAN50
class class-default
  set precedence 0
  service-policy bw376M
policy-map bw600M
description ***************  VLAN 40 Web  ***************
class class-default
  police 600000000 8000 exceed-action drop
policy-map VLAN40
class class-default
  set precedence 4
  service-policy bw600M
policy-map bw6M
description ***************  VLAN 30 Scada  ***************
class class-default
  police 6000000 8000 exceed-action drop
policy-map VLAN30
class class-default
  set precedence 6
  service-policy bw6M
policy-map bw2M
description ***************  VLAN 20 Cameras  ***************
class class-default
  police 2000000 8000 exceed-action drop
policy-map VLAN20
class class-default
  set precedence 7
  service-policy bw2M
policy-map bw16M
description ***************  VLAN 10 IPMux  ***************
class class-default
  police 16000000 8000 exceed-action drop
policy-map VLAN10
class class-default
  set precedence 5
  service-policy bw16M
3) Configure each fastethernet access interface this way:
interface FastEthernet0/1
switchport mode access
mls qos vlan-based
interface FastEthernet0/13
switchport access vlan 10
mls qos vlan-based
interface FastEthernet0/19
switchport access vlan 20
mls qos vlan-based
interface FastEthernet0/25
switchport access vlan 30
mls qos vlan-based
interface FastEthernet0/37
switchport access vlan 40
mls qos vlan-based
interface FastEthernet0/41
switchport access vlan 50
mls qos vlan-based
4) Configure trunk interfaces this way:
interface GigabitEthernet0/1
switchport mode trunk
mls qos vlan-based
5) Assign the policy maps to the SVIs:
interface Vlan10
no ip address
service-policy input VLAN10
interface Vlan20
no ip address
service-policy input VLAN20
interface Vlan30
no ip address
service-policy input VLAN30
interface Vlan40
no ip address
service-policy input VLAN40
interface Vlan50
no ip address
service-policy input VLAN50
end of configuration
Is this correct? Or an I missing something?
Please your help.
HM
Message was edited by: Hector Miranda
Can anybody post an answer, please?
I really need to know if the above configuration is correct or if I'm missing some other commands...
Thanks in advance,
Hector
Well, this is kind of frustrating....
Where you able to deploy your configuration successfully?  I need to do something very similar.
Hi Hector,
Best regards,
Andras
Thank you, Andras!!
It was for confirmation before implementing it in the production network.
I'll grab any logs or issues, if they appear.
Thanks again!
Hector
Hi Hector,
Best regards,
Andras
