VLAN config help needed
keith.magyar1
Community Member
Hi, I would appreciate any help I can get on this problem. I have a  WS-C3750X-48P-S core that I am having some trouble with.
My goal is to move clients on VLAN1 (172.16.0.0/16) to two new vlans , vlan11 and vlan119, thats one for server and one for clients. I am connecting to a Meraki MX100 via port 29 on this switch.
My problem is that If I put myself on port 11 for example and assign myself a static IP of 10.3.1.2 gateway 10.3.1.1, I can ping my Meraki vlan interface and the internet but zero of anything else including the core switch that I am plugged into at port 11. If I chaneg my gateway to 10.3.1.254, I get no reply from anything.
Below are the core config and the Meraki 100 VLAN config along with the port settings. What am I missing here?
USDAYCORE#sh start
Using 12884 out of 524288 bytes
! Last configuration change at 10:40:17 EST Thu Nov 3 2016 by core
! NVRAM config last updated at 10:40:28 EST Thu Nov 3 2016 by core
version 12.2
no service pad
service password-encryption
service sequence-numbers
hostname USDAYCORE
boot-start-marker
boot-end-marker
enable secret 5 $1$sat3$INN4OF0IT/nbLHXHcuqOY/
username core privilege 15 secret 5 $1$A3IC$OBIRaX0.3s1MQbzsoNFdH0
username misadmin privilege 15 password 7 140507050201387F70
no aaa new-model
clock timezone EST -5
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip routing
ip domain-name globe-motors.com
ip name-server 172.16.200.14
ip name-server 172.16.200.46
ip device tracking
crypto pki trustpoint TP-self-signed-3106995200
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3106995200
revocation-check none
rsakeypair TP-self-signed-3106995200
crypto pki certificate chain TP-self-signed-3106995200
certificate self-signed 01 nvram:IOS-Self-Sig#3031.cer
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
port-channel load-balance src-dst-ip
vlan internal allocation policy ascending
ip ssh authentication-retries 5
lldp run
class-map match-all VOIP
policy-map Voice
interface Port-channel1
description Barracuda LAG
interface Port-channel2
description DAYIAP2_DRAFT01
switchport trunk allowed vlan 1,2,21,75
switchport mode trunk
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet1/0/1
description DAYIAP3_LAB0
switchport trunk allowed vlan 1,2,11,21,75,119
spanning-tree portfast disable
interface GigabitEthernet1/0/2
description Molly Gillium
switchport trunk allowed vlan 1,2,11,75,119
interface GigabitEthernet1/0/3
description Darren Taylor
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description CableDrop105_Near_Shane_Knick_Office
interface GigabitEthernet1/0/6
description AT&T MPLS NETWORK
interface GigabitEthernet1/0/7
description Darren Taylor_202
interface GigabitEthernet1/0/8
description DAYIAP4_SALES0
interface GigabitEthernet1/0/9
description DAYBACKUP_BARRACUDA
channel-group 1 mode active
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description TEST PORT
interface GigabitEthernet1/0/12
description DAYIAP2_DRAFT1
interface GigabitEthernet1/0/13
description DAYIAP5_ADMIN0
interface GigabitEthernet1/0/14
description LKNIGHT
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
description S-Day1Flr2
interface GigabitEthernet1/0/17
description Guest_Wifi VLAN 75
switchport trunk allowed vlan 1,11,75,119
interface GigabitEthernet1/0/18
switchport trunk allowed vlan 1,11,119
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
description S-DayTestLab
switchport trunk allowed vlan 1,2,11,25,75,119
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
duplex full
interface GigabitEthernet1/0/24
description Connection to 2800 Router
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
switchport trunk allowed vlan 1,2,11,119
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
description Meraki LAN2
switchport trunk allowed vlan 1,2,6,10,11,18,20,25,30,75,119,122
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
description GuestTest
switchport access vlan 75
switchport mode access
interface GigabitEthernet1/0/37
description DAYIAP6_ENG0
interface GigabitEthernet1/0/38
description OWNCLOUD
switchport access vlan 4
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
description 3rd Floor WAP
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
description DAYIAP1_AIRHND1
interface GigabitEthernet1/0/45
description PRIMARY IPLEX
switchport access vlan 2
interface GigabitEthernet1/0/46
description BACKUP IPLEX
interface GigabitEthernet1/0/47
description SKYCUBE_CBTS_SIP
interface GigabitEthernet1/0/48
description SANNetwork Trunk
switchport trunk allowed vlan 1,2,11,25,119,200
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
description Data Network
ip address 172.16.0.2 255.255.0.0
interface Vlan2
description Voice Network
ip address 192.168.16.1 255.255.255.0
interface Vlan5
description 3CX_Phone
ip address 192.168.5.1 255.255.255.0
interface Vlan11
description US-DAY-SRV
ip address 10.3.1.254 255.255.255.0
interface Vlan19
description Foundry
no ip address
interface Vlan20
description TestEnv
ip address 172.20.0.1 255.255.0.0
ip access-group DenyVLAN out
interface Vlan21
description US-DAY-GST
no ip address
ip access-group RestrictGuestWireless in
interface Vlan25
ip address 172.25.0.1 255.255.0.0
interface Vlan75
description Guest Wireless
ip address 192.168.75.1 255.255.255.0
interface Vlan119
description US-DAY-GEN
ip address 10.3.92.254 255.255.255.0
interface Vlan200
description EMC_SAN_NETWORK
ip address 172.200.0.1 255.255.0.0
router eigrp 2275
network 172.16.0.0
eigrp stub connected summary
ip default-gateway 172.16.0.2
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.11
ip route 10.0.0.0 255.0.0.0 172.16.0.11
ip route 10.10.18.0 255.255.255.0 172.16.0.3
ip route 10.10.19.0 255.255.255.0 172.16.0.3
ip route 10.10.21.0 255.255.255.0 172.16.0.3
ip route 10.10.22.0 255.255.255.0 172.16.0.3
ip route 10.140.1.0 255.255.255.0 10.3.1.1
ip route 10.140.92.0 255.255.255.0 10.3.1.1
ip route 72.75.211.132 255.255.255.255 10.10.1.1
ip route 172.19.0.0 255.255.0.0 172.16.0.3
ip route 172.22.0.0 255.255.0.0 172.16.0.6
ip route 172.23.0.0 255.255.0.0 172.23.0.1
ip route 172.23.253.0 255.255.255.0 172.16.0.6
ip route 172.25.1.0 255.255.255.0 172.16.0.3
ip route 172.31.0.0 255.255.0.0 172.16.0.6
ip route 172.32.0.0 255.255.0.0 172.16.0.10
ip route 172.200.0.0 255.255.0.0 172.16.0.6
ip route 192.168.4.0 255.255.255.0 172.16.0.3
ip route 192.168.18.0 255.255.255.0 192.168.16.5
ip route 192.168.19.0 255.255.255.0 192.168.16.3
ip http server
ip http authentication local
ip http secure-server
ip access-list extended RestrictGuestWireless
permit ip 192.168.75.0 0.0.0.255 host 172.16.0.2
permit ip 192.168.75.0 0.0.0.255 host 172.16.0.9
permit ip 192.168.75.0 0.0.0.255 host 172.16.0.15
permit ip host 172.16.6.14 192.168.75.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 172.16.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.18.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.19.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.23.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.21.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 172.200.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 10.10.18.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.19.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.20.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.21.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.22.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 10.10.0.0 0.0.255.255
deny ip 192.168.75.0 0.0.0.255 192.168.16.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 192.168.18.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 192.168.19.0 0.0.0.255
deny ip 192.168.75.0 0.0.0.255 192.168.17.0 0.0.0.255
permit ip any any
permit ip 192.168.75.0 0.0.0.255 host 192.168.75.2
permit ip host 192.168.75.0 0.0.0.246 172.16.0.9
permit ip host 192.168.75.0 0.0.0.253 192.168.75.2
ip sla enable reaction-alerts
logging 172.16.6.14
snmp-server community private RO
snmp-server community monitor RO
snmp ifmib ifindex persist
line con 0
line vty 0 4
session-timeout 120
exec-timeout 120 0
login local
transport input telnet ssh
line vty 5 15
session-timeout 120
exec-timeout 120 0
login local
ntp clock-period 36027228
ntp server 172.16.200.46
end
USDAYCORE#
Routes at Meraki
Routing
VLANs
Routes
Subnet Type Details
172.16.0.0/16 Local VLAN
Name US-DAY-LGY
MX IP 172.16.0.11
VLAN 1
In VPN yes
192.168.16.0/24 Local VLAN
Name US-DAY-LGY-VCE
MX IP 192.168.16.5
VLAN 2
In VPN yes
10.3.1.0/24 Local VLAN
Name US-DAY-SRV
MX IP 10.3.1.1
VLAN 11
In VPN yes
10.3.224.0/24 Local VLAN
Name US-DAY-GST
MX IP 10.3.224.1
VLAN 21
192.168.75.0/24 Local VLAN
Name GLB-Guest
MX IP 192.168.75.11
VLAN 75
10.3.92.0/24 Local VLAN
Name US-DAY-GEN
MX IP 10.3.92.1
VLAN 119
In VPN yes
192.168.19.0/24 Static Route
Name US-TRY-VCE_LCY
Next hop IP 172.16.0.2
Active always
In VPN yes
172.19.0.0/16 Static Route
Name US-TRY-LGY
Active always
In VPN yes
172.32.0.0/32 Static Route
Name DAY-CLIENT-VPN
Active always
In VPN yes
Port config at Meraki MX100
Per-port VLAN configuration
Port [Sorting up]
Enabled?
Type
VLAN
Allowed VLANs
LAN 2 enabled trunk Drop untagged traffic All
LAN 3 enabled access VLAN 2 (US-DAY-LGY-VCE) —
LAN 4 disabled — — —
LAN 5 disabled — — —
LAN 6 disabled — — —
LAN 7 disabled — — —
LAN 8 disabled — — —
LAN 9 disabled — — —
LAN 10 disabled — — —
LAN 11 disabled — — —
So if you are using a VoIP phone on the port the configuration would be:
switchport access vlan 119
switchport voice vlan 2
13 Replies 13
chrihussey
If you are connecting a PC or laptop to port 11 I'll bet the device is still in VLAN 1. How the Meraki responds is beyond me from the VLAN 11 interface, I cannot explain, but that could just be the way it handles the packet.
Regardless, configure the port as an access port in VLAN 11 and see if that makes things work for you:
glen.grant
  Port 11 is setup as a trunk , change it to an access port  in vlan 11 and set your DG as 3.254 on your client and retry your ping tests .  Its not going to ping right if the port is set as a trunk .
I changed port 11 to an access port allowing vlan 11 and it works as you mentioned. Though can you help me understand why this works? I was understanding that a port set to trunk can allow multiple vlans across it? My lack of understanding this tells me that it should work. Any help is appreciated and thanks for the reply.
A dot1q trunk inserts a 4 byte tag in the IP header. This identifies the VLAN to which the packet belongs. The native VLAN for the trunk is untagged. So when you plugged your PC into the port the untagged packets were assumed to be in VLAN 1.
If you have a device that needs to send multiple VLANs, then that device's interface will need to be configured as a trunk.
If your just connecting a single network device (PC, laptop, printer, etc) configure the port as an access port in the proper VLAN and you should be OK.
Just for my clarification, You said devices interface, you mean switch port, correct?
and
switchport trunk encapsulation dot1q was what prevented communication between vlans?
It's difficult to understand what requirements users are trying to fulfill just by short discussion posts. In your case, all ports were configured as trunks and there were servers involved. So if you had a device like a virtual server that had multiple VMs in different subnets /VLANs, that server interface would need to be a trunking interface and the switch port would have to be set accordingly.
However, if that does not apply here, and you're connecting single IP PCs, servers, etc.,  just set up the switch ports as access ports in the proper VLAN. I hope that makes sense in that it answers your first question.
As for the second question, it was the fact that you had the port defined as a trunk along with the encapsulation. On some platforms you have to specify the encapsulation to allow the "switchport mode trunk" command at all.
This would not prevent the interface from coming up if when you connect your PC to the port. However, by default the native vlan on a dot1q trunk is VLAN 1 and the packets in this VLAN are for the most part no different than any other Ethernet packet. All other packets in other VLANs insert a tag in to the IP header. So when you changed the IP address of your PC, it stayed in VLAN 1. Like I said, how the Meraki allowed some of the results in this state I cannot say.
When you defined it as an access port in VLAN 11, the packet from your PC enters the switch in that VLAN, when it leaves the switch on the trunk port to the Meraki, the switch inserts that 4 byte tag into the IP header to identify it is in VLAN 11. Similarly, when the Meraki sends the packet back to the switch, it sends it with the same tag, the switch receives the packet, strips the tag and sends it to the access port.
Kind of wordy I know, but I hope that helps. If you have any questions just let me know.
Here is a slightly different perspective on explaining the issue. As explained in previous posts when you configure a switch port as a trunk it does support multiple vlans to be carried on that port. One of those vlans is treated as the native vlan and frames in that vlan are sent without vlan tags while frames in all other vlans are sent with vlan tags.
The important point here is what kind of devices connect to switch ports that do support tagged frames. Switches and some servers do support sending Ethernet frames with tags and it is appropriate to connect them on trunk ports. But most host PCs do not support tagged frames. So for these devices it is appropriate to connect them to access ports and not to trunk ports.
Rick
Rick
Still trying to grasp this completely. I failed to mention the fact that I have VLAN 2 for voice (IP Phones), they all pass through to client PCs. I realized this was a problem when I changed gi1/0/3 from trunk to access.
 so how to I assign a different default vlan using
switchport trunk encapsulation dot1q when trunking?
 gi1/0/3 needs to allow both vlan 2 and 119 in this case. Any help to understand is very much appreciated.
Especially if the phones are Cisco phones then what you want to do is to configure the interface as an access port accessing vlan 119 and then in the interface configure voice vlan as 2. This will treat the interface as an access port on vlan 119 for data but will also process phone traffic on vlan 2.
Rick
Rick
Thanks for that information.
Is this a valid question?
how to I assign a different default vlan using "switchport trunk encapsulation dot1q" when trunking?
I need to change the ip address for the Aruba access point on this port to vlan 11. it will carry vlan 75 for guest access and vlan 119 for employee wifi.
Yes it is a valid question if I am understanding what you are asking. Currently the Aruba AP trunks to the switch and has a management IP in VLAN 1 and you want to change the management IP and put it in VLAN 11. I also assume that the management IP of the AP has to be in the trunk's native VLAN (like a Cisco  AP).
switchport trunk native vlan 11
Thank you for your reply, I made the change as follows; for an Access Point on port 37. I wanted to put the AP in the same VLAN that my wireless clients get dhcp from so this is what I have;
description WIFI AP DAYIAP6
switchport trunk native vlan 119
I had a problem but it was due to another AP interfering. I cut the problem out of this reply.
