VLAN connection issue
Hartmann.J
i created a VLAN für test purposes.
I want to secure this VLAN with ACLs lateron.
(havent added any ACLs yet)
since a lot of productive Systems are running in the Network i didn't want to try around too much on the core Switch at the moemnt.
I'm sure i only forgot something minor.
Problem:
My Client with the IP Address 10.14.68.145 can't connect to other Networks / Internet. (I cant even Ping the Gateway of the VLAN)
Config:
VLAN 24
Bereich             10.14.68.144 / 28     to: 10.14.68.159
Mask                 255.255.255.240
Gateway           10.14.68.158
 free                  10.14.68.145            to: 10.14.68.157
Client PC config:
Ip 10.14.68.145
Sm 255.255.255.240
DNS: 10.14.42.71 (our DNS)
Config on Core-Switch:
sh run int vlan 24
interface Vlan24
ip address 10.14.68.158 255.255.255.240
end
interface Port-channel1
switchport
switchport trunk allowed vlan 2-24,30,90,101,104
switchport mode trunk
ip arp inspection trust
no ip address
mls qos trust dscp
ip dhcp snooping trust
end
Member of the Portchannel:
interface TenGigabitEthernet1/1
 switchport
 no ip address
 mls qos trust dscp
 channel-group 1 mode desirable
end
interface TenGigabitEthernet1/2
 switchport
 no ip address
 mls qos trust dscp
end
The Client is connected over 2 Switches These are the Port configs of the trunks / the port
(link to first switch)
interface TenGigabitEthernet6/4
switchport
no ip address
mls qos trust dscp
end
(link to 2nd switch)
interface GigabitEthernet1/0/37
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 30 0 0 0
priority-queue out
mls qos trust dscp
end
(Port on 2nd Switch)
 interface GigabitEthernet0/5
switchport access vlan 24
switchport mode access
spanning-tree portfast
end
VLAN is up and active:
Sh ip int brief
Vlan24 10.14.68.158 YES manual up up
Sh ip route
Gateway of last resort is 10.14.0.250 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 22 subnets, 8 masks
C 10.14.68.144/28 is directly connected, Vlan24
S* 0.0.0.0/0 [1/0] via 10.14.0.250
CoreSwitch: show arp | i Vlan24
Internet 10.14.68.158 - 0013.5fec.6c00 ARPA Vlan24
Client:
Arp -a
Schnittstelle: 10.14.68.145 --- 0xb
Internetadresse     Physische Adresse   Typ
10.14.68.158         00-14-1b-ec-00-00    Dynamisch
10.14.68.159         Ff-ff-ff-ff-ff-ff               Statisch
224.0.0.22             01-00-5e-00-00-16    Statisch
224.0.0.251           01-00-5e-00-00-fb     Statisch
224.0.0.252           01-00-5e-00-00-fc     Statisch
255.255.255.255   Ff-ff-ff-ff-ff-ff               Statisch
Extended Ping from Core Switch with source ip of the VLAN:
ping
Protocol [ip]:
Target IP address: 10.14.0.250
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.14.68.158
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.14.0.250, timeout is 2 seconds:
Packet sent with a source address of 10.14.68.158
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 MS
Thank you for your help!
Hi;
To modify the VTP version you need to convert vtp mode as transparent / server your access switch (switch-1 & Switch-2).
Initially as per the old output the VTP domain was different on Core switch & Access switches which was modified.
Now your scenario become interested if vtp domain is same on all the network, vlan exists then on switches & vlan is allowed on trunk then there is no reason for client  (vlan 24) packet not reach / ping the gateway.
Thanks & Best regards;
15 Replies 15
Georg Pauwen
if you do a 'sh int TenGigabitEthernet1/1 trunk' and 'sh int TenGigabitEthernet1/2 trunk',
is Vlan 24 listed as an allowed Vlan?
yes the VLan is listed as allowed on both ports:
sh int tenGigabitEthernet 1/1 trunk
Port          Mode         Encapsulation  Status        Native vlan
Te1/1         on           802.1q         trunk-inbndl  1
                                      (Po1)
Port          Vlans allowed on trunk
Te1/1         2-24,30,90,101,104
Port          Vlans allowed and active in management domain
Te1/1         2,4-24,90,101,104
Port          Vlans in spanning tree forwarding state and not pruned
sh int tenGigabitEthernet 1/2 trunk
Te1/2         on           802.1q         trunk-inbndl  1
                                      (Po1)
Te1/2         2-24,30,90,101,104
Te1/2         2,4-24,90,101,104
The trunks look ok. Try and reenable 'ip routing' globally on the core switches where you have Vlan 24 configured, that sometimes helps...
Thanks for the tip,
i dont want to try that nw incasue something goes wrong, and there are a lot of productive Systems on the netweork at the Moment.
I have to wait untill People stop working for this i guess
ahmedshoaib
Level 9
Level 9
Hi;
I have following question after seeing the configuration:
1. Po1 (T1/1 & T1/2) is connected to which switch?
2. As you mentioned Client is connected to 2 switch, will client configure as Active/Standby teaming?
3. Can you verify client switch have vlan 24 via show vlan brief command?
4. Can you also verify trunk interface on client switch (First & Second switch)?
Po1 is the Connection to the 2nd core-Switch
I'm not exactly sure what you mean
Yes both other Switch have VLAN 24
from core to 1st Switch :
sh int te6/4 trunk
Te6/4         on           802.1q         trunking      1
Te6/4         1-4094
Te6/4         1-2,4-24,90,101,104,900
from 1st to 2nd Switch :
sh int gi1/0/37 trunk
Gi1/0/37    on               802.1q         trunking      1
Gi1/0/37    1-4094
Gi1/0/37    1-2,4-24,90,101,104,900
Hi;
Can you explain me below statement:
"The Client is connected over 2 Switches These are the Port configs of the trunks / the port"
And also describe the client connectivity.
It Looks like this:
Core-Switch1<-----Po1(trunk)  ------>Core-Switch2
    |    int te6/4 (trunk)
    |    int te2/0/1 (trunk)
Switch 1
    |    int gi1/0/37 (trunk)
    |    int gi0/10 (trunk)
Switch 2 -int gi0/5-----------------> Client
On the Client Pc i cannot reach anything, i cant even ping my Gateway on VLAN 24 wich is 10.14.68.158
when i did a arp -a eralier today the result was
Client:
Arp -a
when i did it again now the result was
Client:
Arp -a
first and last line missing.
Hi;
Now my doubt is going on 2 things:
1 - Switch-1 (middle switch) either vlan 24 is not created (verify via show vlan brief).
2 - please verify the vtp domain on all 3 switches (Core, Switch-1 & Switch-2)
The VLAN is active on Switch 1 & Switch 2
Switch1: sh vlan brief
VLAN Name                              Status    Ports
24       TestVLAN24                   active
Switch2: sh vlan brief
24       TestVLAN24                   active    Gi0/5
Core Switch: sh vtp status
VTP Version                                                     : 2
Configuration Revision                                     : 56
Maximum VLANs supported locally                 : 1005
Number of existing VLANs                              : 31
VTP Operating Mode                                       : Server
VTP Domain Name                                          : Domainname
VTP Pruning Mode                                           : Disabled
VTP V2 Mode                                                   : Disabled
VTP Traps Generation                                     : Enabled
MD5 digest                                                       : 0xF8 0x59 0xAB 0x49 0x07 0x72 0xEE 0x34
Configuration last modified by 10.14.31.254 at 9-1-16 12:25:44
Local updater ID is 10.14.31.254 on interface Vl2 (lowest numbered VLAN interface found)
Switch1:sh vtp status
VTP Version capable             : 1 to 3
VTP version running              : 1
Device ID                                 : 0008.3036.3e00
Feature VLAN:
VTP Operating Mode                         : Client
Maximum VLANs supported locally   : 255
                                    0xBD 0x31 0x74 0x52 0x5A 0x57 0x58 0x89
Switch2:
sh vtp status
Device ID                                 : f09e.6384.c900
Feature VLAN:
Hi;
Now here the issue is with reference to VTP domain;
Please change the VTP domain name to Domainname  & VTP Version 2 on both Switch-1 & Switch-2.
the Name was the same on all them, i forgot to edit the others.
When i try to Change the VTP Version on Switch2 i get:
vtp version 2
Cannot modify version in VTP client mode unless the system is in VTP version 3
Hi;
i changed the VTP Version to 2 and at the same time i noticed i'm getting
%SW_DAI-4-DHCP_SNOOPING_DENY:
on the port in which my Client is connected.
I added
dhcp snooping trust
on the port and it's working now.
Thanks for your help!
