Vlan for Management Nexus/Catalyst switches
Jeffrey_233
Hi All
So i have a pair of Nexus 3500's as my core's and before upgrading the firmware to the recommended stable version.
I had a vlan that i could ssh into and do configurations there. But this is no longer working. I did follow the upgrade guide and did run the setup to update the copp policies.
I can connect into one of the other Vlan IP to do this.
Did i miss something on my management vlan?
On each of my Catalyst switches i have the same vlan and unique IP's to each switch.
Some work and some don't but I can't figure out why some don't.
The 10GB ports are trunked and have the vlan included.
Coming for a Dell switch background that was all i needed to do.
Not sure what i missed?
5 Replies 5
balaji.bandi
First what NEXUS OS you were before, and what version did you upgrade to. The upgrade should not break your VLAN connection until any Bug was affected by the target version you upgraded to.
what is the VLAN of Management ? are you able to ping from your PC to that IP address?
If you have other modes of access, if you have taken the backup, I would advise comparing to config before the upgrade and after the upgrade.
show IP interface brief ( you should see VLAN interface up/up)
if the ManangementVLAN in a different VRF you need to check with VRF information.
Not sure we follow this, what VLAN is this, what you can able to do this please explain more so we can understand better to advise.
BB
I upgraded from nxos 9.2.4
Current version is nxos 9.3.8
So my interface mgmt0 is vrf member management.
interface mgmt0
 ip address 10.10.60.2/24
line console
line vty
access-class dst-vty-access in
boot nxos bootflash:/nxos.9.3.8.bin
feature signature-verification
And my management Vlan also had management assigned to it.
interface Vlan60
  description mgt
  no shutdown
  management
  ip dhcp relay address x.x.x.x
  vrrp 215
    address x
    no shutdown
This is what i have.
Both on the same device, So Looks like they are conflicting the IP address ?
are you able to ping  10.10.60.2 also VRRP IP address X ?
Under VLAN you mention Management :
management - Allow in-band management access to VLAN Interface IP address
If this is the VLAN you using for Management, shutdown mgmt0 ( and test it)
BB
Hello
interface mgmt0
interface Vlan60
  description mgt
  no shutdown
  management
  vrrp 215
    address x
    no shutdown
 Your mgt interface is in a VRF and vlan 60 isnt, that's why you can have conflicting ip address and not able to reach via vlan 60
Kind Regards
Paul
managment interface is NSK is L3 and no need any HSRP VRRP. when you ping to one NSK you ping to that not ping to VIP of HSRP
so VLAN no need, why you config it?
ALSO you must config under
interface management
ip default route to Next-hop the managment is connect.
https://ciscodatacenter.files.wordpress.com/2009/12/vpc-configuration_guide_c07-543563.pdf
