VLAN interface problem
manui31804
Community Member
I had to configure remotely a new VLAN interface on a cisco switch that had this vlan configuration :
(I am connected remotely using telnet on 192.168.130.32)
interface Vlan1
ip address 192.168.130.32 255.255.255.0
no ip route-cache
So as I understood the vlan 1 is the default Vlan, and i can ping the ip address 192.168.130.32
I decided after that to create a new vlan 201 with ip adress 10.58.197.32 "corporate ip adress" :
interface Vlan201
ip address 10.58.197.32 255.255.255.0
no ip route-cache
shutdown
If I remember shutdown means the interface is just created but not available. So now i Have this vlan configuration :
interface Vlan1
no ip route-cache
interface Vlan201
no ip route-cache
shutdown
I used after that the command "no shutdown" on this interface vlan 201 and then I lost connection And I was unable anymore to ping the 192.168.130.32.
Can someone explain me why I can't ping anymore the 192.168.130.32 please?
I can't also ping the 10.58.197.32 but this is normal. The problem is that this switch is on a remote site and I can't access it anymore.
I have to do 500km to plug my console cable I suppose...
Thanks a lot for your help/explanation
emmanuel
Well my bad, I had assumed the switch you were using was layer 3 capable. Looks like your problem is indeed that. As stated by Alain, the 2950 is not capable of having more then one SVI. In order to make this work in the way you are currently trying to, you will need to upgrade the switch.
However this does not preclude adding a second VLAN to the switch and trunking it off to a switch that does have layer 3 capability or a sub-interface on a router.
What does this switch connect back to?
11 Replies 11
Hello
Did you save your changes? - If not the quickest way to get this back is to get someone to power down/up the switch you have lost connection to?
or get the same person to plug in a console cable and have them to revert your changes
By the way this "10.58.197.32 "corporate ip address" was it your wan interface address?
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
Gregory Snipes
Level 11
Level 11
I would need to see more of the configuration to be sure (and a diagram of how this is connected would be helpful too) but I would wager that this is an issue with the default gateway/route.
If you have input the "ip default-gateway" command into this device to point it out of its subnet then when you switch the device over into multilayer switching, the "ip default-gateway" command is no longer used and you must switch over to using a default route. The command to enter a default route is "ip route 0.0.0.0 0.0.0.0 ".
manui31804
Community Member
Thanks for your answers.
@pdriver, this is a good idea to restart the switch cause I saved the changes but before adding the command line "no shutdown" so that should work !
10.58.197.32 is a LAN adress you should see this switch as a simple layer 2 switch.
@Gregory, it is just delivering network to 2 or 3 offices nothing else and it is not suposed to do some multivlan routes but you're right, I had a default gateway that targeted the router of this site. if I understand, by adding a new vlan interface, this disable the default gateway so that should explain why I can't telnet on it.
I did this test on a little switch before doing that on the other ones.
Is it possible then to let the default gateway but to add another vlan interface  ? like I was trying to do?
(I'm french and my english is not perfect, if you don't understand something, please ask 😉 )
Thanks again for your help
You english is not a problem, defiantly better than my french.
There is no issue with switching this device over to multi layer switching. You just need to add a default route if you are going to. The "ip route 0.0.0.0 0.0.0.0 " is how you set this. It can be set in addition to the "ip default-gateway " command. The former will be used if the device is performing multi-layer switching, the later will be used if the device is performing only layer 2 switching.
Please let me know if this needs further clarification.
if this is a pure L2 switch like a 2950 then it can't have more than one SVI up at the same time and so when you no shut the vlan 201 interface you put the vlan 1 interface down and as you were connected to that IP then you lost your telnet session.
Alain
mahmoodmkl
Level 11
Level 11
Please let us know the model of this switch
stephen jeffrey
Frequent Visitor
Frequent Visitor
Hi, Cant help with the origional issue. But a great command is the "reload in XX" command, the XX being how long before the switch reloads.just dont save any config as you go. If you make a mistake and disconnect yourself just go for a coffee and wait for the device to reload and be back where you started. Saved me quite a few miles driving. you can cancel by issuing the "reload cancel" if everything works.
hope that helps in the future.
please let me know the model number of the switch. from your issue it looks like the device should be a layer 2. that is why when u created a new vlan the oldworking vlan wnet inactive.
Hi everyone and thanks all for your answers, the swich is a 2959 24 ports
@gregory As I understand the default route should not be used on this switch I think cause it's a command line I suppose for a multi vlan rooting (I don't know if you understand multi vlan rooting we say "routage inter vlan" in french) and in this case I just want to add a vlan and an ip adress on its interface nothing else.
@cadet alain, thanks for the information. I think i misunderstood one thing. I used the interface Vlan command line but I saw there is also a vlan command without "interface". Instead of creating a vlan interface in my case it should be better to create a vlan that makes more sense for me what do you think about that?
@ Stephen Jeffrey, Thanks a lot for this tip ! So in case of crash or disconnection, the switch will reload automatically and I will be able to have some other tests this is great 🙂
here is the configuration of the switch before I was disconnected and before I forced the "no shutdown":
Current configuration : 4237 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname sw-25
enable secret 5 $1$PgiB$I63D74GW1IEuuWoAVuyu2.
wrr-queue bandwidth 60 10 30 0
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport voice vlan 101
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast
interface FastEthernet0/2
mls qos trust cos
interface FastEthernet0/3
mls qos trust cos
interface FastEthernet0/4
mls qos trust cos
interface FastEthernet0/5
mls qos trust cos
interface FastEthernet0/6
mls qos trust cos
interface FastEthernet0/7
mls qos trust cos
interface FastEthernet0/8
mls qos trust cos
interface FastEthernet0/9
mls qos trust cos
interface FastEthernet0/10
mls qos trust cos
interface FastEthernet0/11
mls qos trust cos
interface FastEthernet0/12
mls qos trust cos
interface FastEthernet0/13
mls qos trust cos
interface FastEthernet0/14
mls qos trust cos
interface FastEthernet0/15
mls qos trust cos
interface FastEthernet0/16
mls qos trust cos
interface FastEthernet0/17
mls qos trust cos
interface FastEthernet0/18
mls qos trust cos
interface FastEthernet0/19
mls qos trust cos
interface FastEthernet0/20
switchport access vlan 101
switchport mode access
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
switchport nonegotiate
mls qos trust cos
interface GigabitEthernet0/2
mls qos trust cos
interface Vlan1
no ip route-cache
interface Vlan201
no ip route-cache
shutdown
ip default-gateway 192.168.130.12
ip http server
snmp-server community public RO
snmp-server community private RW
line con 0
password 7 11041A3A041108
login
line vty 0 4
login
line vty 5 15
login
end
and this is what I need :
vlan 1 : 192.168.130.32
vlan 201 : 10.58.197.32
default gateway : 192.168.130.12
In another way, I want to add a new vlan and apply an ip adress on it. This is what I did on my 3com switches, but maybe cisco is a little bit different.
Thanks again for your time and your help.
Emmanuel
Hi Gregory,
You're right this is the answer. By comparing another switch 2950 configuration on another site that is configured in the same way I have 2 vlan interfaces with 2 different ip adresses but one interface is "shutdown".
The first switch i was comparing was a 3750 and it is a layer 3... that's why I thought it was possible but now it's clear 🙂
Thanks all for your quick answers it is really nice how fast i received answers from you and it helped me to understand better the vlan configuration and tips for cisco switches. Maybe if I have other questions I will open a new topic ;-).
Thanks again
