Vlan missing in running-config
michal.adam
i am confused.
I have on 3750X stack with a few vlan
vvlansw06# sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/6, Gi1/0/10, Gi2/0/5
                                                Gi2/0/6, Gi2/0/37
10   LAN_10                           active    Gi1/0/16, Gi1/0/17, Gi1/0/19
                                                Gi1/0/20, Gi1/0/21, Gi1/0/22
                                                Gi1/0/27, Gi1/0/28, Gi1/0/29
                                                Gi1/0/30, Gi2/0/16, Gi2/0/17
                                                Gi2/0/19, Gi2/0/20, Gi2/0/21
                                                Gi2/0/22, Gi2/0/27, Gi2/0/28
                                                Gi2/0/29, Gi2/0/30, Po7, Po8
                                                Po11, Po15, Po16, Po20, Po22
                                                Po24, Po26, Po27
20   DMZ_20                           active    Gi1/0/34, Gi1/0/35, Gi1/0/36
                                                Gi2/0/34, Gi2/0/35, Gi2/0/36
                                                Po9, Po13, Po17
30   TP_30                            active
40   MGMT_40                          active
51   KHP_51                           active
52   MOVO_52                          active
53   PVK_53                           active
54   SAS_54                           active
55   SVAS_55                          active
56   VOSS_56                          active
57   VP_57                            active
58   SCVK_58                          active
59   CC_59                            active
60   1SCV_60                          active
100  CSHB_100                         active    Po10, Po14, Po18
110  CSLM_110                         active    Po21, Po23, Po25
120  CSEX_120                         active
130  FGHB_130                         active    Gi1/0/45, Gi1/0/46, Gi2/0/45
                                                Gi2/0/46
200  internet_200                     active    Gi1/0/47, Gi2/0/47
300  FR_300                           active
999  VLAN0999                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
But in running-config and startup-config I have only this
interface Vlan1
no ip address
interface Vlan30
description ***Trunk to Teplice***
no ip address
interface Vlan40
ip address 172.30.250.30 255.255.255.0
interface Vlan100
no ip address
interface Vlan300
description *BT-InfoNet*access to FR
no ip address
interface Vlan999
no ip address
where are the others vlan?
thank you
2 Accepted Solutions
John Blakley
The vlans that have interfaces assigned are considered L3 SVIs. Whenever a vlan is created, it doesn't create the SVI automatically because the vlan is considered L2. When you create the vlan, you can create an interface to attach to it which in turn creates the L3 SVI. You can create an interface that points to a non-existent vlan, but the vlan will show down/down until the L2 vlan is created.
HTH,
John
HTH, John *** Please rate all useful posts ***
Reza Sharifi
If you just create layer-2 vlans and you are in vtp server or client mode than sh run does not display the vlans
see this link:
http://www.cisco.com/en/US/products/hw/switches/ps5213/products_tech_note09186a0080a49dbf.shtml
John Blakley
HTH,
John
Reza Sharifi
see this link:
Reza gave you the answer , your switch is either vtp server or client mode .  If it was in tranparent mode the l2 vlans would show in the config.
Saw this on a 3650 - except it only applied to VLAN's with a low number (seemed to be sub-1000) and VLAN's above that appeared fine in the running config! Go figure
Going to VTP transparent mode fixed it totally
