I have a set of 2950 and 2970 switches in a VTP domain controlled by a 4506 core switch, with a number of VLANs.
I want to be able to pipe VLAN traffic from one edge device to another, using a VLAN - but, I then want the traffic to go out to a cisco wireless access point controlled by another organisation - which isn't part of my VTP domain, and also doesn't recognise my VLAN.
Is there some way I can configure the edge device (a WS-2950G-24-EI) to ignore or drop the VLAN information?
Thanks for your help
Phil
