vlan router on a stick internet connection
hanighaderi
Hi Guys, I would need help to correct my code. I am trying to setup the lab on Vlan topics. I have connectivity with all my vlans and I can ping from all my vlan, the FastEthernet 0/1 which is connected to internet. But I dont have internet connection on my Vlans!! which part I am doing wrong ? Thanks for help. below is my Router commands. Thanks
Oh I Have Router 2800 connected to Switch 3500XL
Router 2800
Current configuration : 1886 bytes
version 12.4
service password-encryption
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
ip name-server 4.2.2.2
voice-card 0
no dspfarm
interface FastEthernet0/0
description LINK TO SWITCH
no ip address
ip nat inside
duplex full
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
no snmp trap link-status
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
interface FastEthernet0/1
ip address 67.21.6.xx 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 67.21.6.xx
ip dns server
ip http server
no ip http secure-server
access-list 101 permit ip any any
control-plane
Switch 3500XL
hostname witch1
enable secret 5 XXXXX
ip subnet-zero
no ip domain-lookup
description INTERNET ROUTER CONNECTION
duplex full
switchport mode trunk
interface FastEthernet0/2
duplex full
speed 10
interface FastEthernet0/3
duplex full
speed 10
interface FastEthernet0/4
duplex full
speed 10
interface FastEthernet0/5
duplex full
speed 10
interface FastEthernet0/6
duplex full
speed 10
interface FastEthernet0/7
duplex full
speed 10
interface FastEthernet0/8
duplex full
speed 10
interface FastEthernet0/9
duplex full
speed 10
interface FastEthernet0/10
duplex full
speed 10
interface FastEthernet0/11
duplex full
interface FastEthernet0/12
duplex full
speed 10
interface FastEthernet0/13
duplex full
speed 10
interface FastEthernet0/14
duplex full
speed 10
interface FastEthernet0/15
duplex full
speed 10
interface FastEthernet0/16
duplex full
speed 10
switchport access vlan 10
interface FastEthernet0/17
duplex full
interface FastEthernet0/18
speed 10
interface FastEthernet0/19
duplex full
speed 10
interface FastEthernet0/20
duplex full
speed 10
interface FastEthernet0/21
duplex full
speed 10
interface FastEthernet0/22
duplex full
speed 10
interface FastEthernet0/23
duplex full
speed 10
interface FastEthernet0/24
duplex full
speed 10
switchport access vlan 20
interface FastEthernet0/25
duplex full
speed 10
interface FastEthernet0/26
duplex full
speed 10
interface FastEthernet0/27
duplex full
speed 10
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
switchport access vlan 30
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
switchport access vlan 40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
switchport access vlan 50
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 192.168.1.10 255.255.255.0
no ip directed-broadcast
no ip route-cache
interface VLAN10
ip address 192.168.10.2 255.255.255.0
no ip route-cache
shutdown
interface VLAN20
ip address 192.168.20.2 255.255.255.0
no ip route-cache
shutdown
interface VLAN30
ip address 192.168.30.2 255.255.255.0
no ip route-cache
shutdown
interface VLAN40
ip address 192.168.40.2 255.255.255.0
no ip route-cache
shutdown
interface VLAN50
ip address 192.168.50.2 255.255.255.0
no ip route-cache
shutdown
ip default-gateway 192.168.1.1
2 Accepted Solutions
Gregory Snipes
Level 4
Level 4
Your issue here is your NAT configuration. You need to denote all of the sub-interfaces as NAT inside interfaces, and you need to configure the translation:
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
ip nat inside source list 100 interface FastEthernet0/1 overload
Gregory Snipes
Level 4
Level 4
On an additional but unrelated note:
The 3500XL does not support the use of multiple SVIs. You could only ever use one of the six SVIs you have created.
Gregory Snipes
Level 4
Level 4
Gregory Snipes
Level 4
Level 4
Thanks Gregory for your both posts. It is working now and I can Internet connection.
That's great to hear, I'm glad everything worked out. Please remember to mark the correct solution for future forum searchers.
