VLAN routing query in Cisco 3560 switch with IOS 12.2.55
puneitsupport
I am having Cisco 5510 ASA where I have created vlans.
Using 3COM 4500 switch to terminate thsoe vlans.
I want to replace 3COm switch with Cisco 3560 switch.
I created vlans & trunk ports. [ using siwtch port access,trunk port command,no shut, encapsulation used for trunk. ]
Nothing else.
Now the problems are
Subnets are not able to talk with each other
Subnets are unable to take IP from DHCP server on ASA
What addition commands I need to use in Cisco switch so that all subnets can talk each other?
In 3COM switch I can see some routing entries. Not sure how can I add thsoe entries in Cisco switch via command line.
I haven't worked on Cisco switch since long time.
Any help with detail commands which I need to use in Cisco switch so that all vlans can to each other?
I can not do any modifications in ASA as of now.
5 Replies 5
Steve Fuller
Level 9
Level 9
If the 3COM 4500 series switch is/was doing the routing you'll likely have to create Switch VLAN Interface (SVI) with the interface vlan com mand, and then add the IP address, DHCP helper address etc., within interface vlan context.
interface vlan
no shut
ip address
ip helper-address
You're likely to need a routed connection to the Cisco ASA and some form of routing for the address of the DHCP server.
If you're able to post the configuration from the 3COM switch we can probably figure out exactly what the configuration for the Catalyst 3560 switch should be.
Here you go.
Rather than try to figure this out from the screenshots, are you able to telnet/SSH into the 3COM switch and post the output of the display current-configuration command?
Here you go  >>>
[4500]display current-configuration
private-group-id mode standard
local-server nas-ip 127.0.0.1 key 3com
domain default enable system
igmp-snooping enable
undo password-control aging enable
undo password-control length enable
password-control login-attempt 3 exceed lock-time 120
radius scheme system
domain system
local-user admin
service-type ssh telnet terminal
level 3
local-user manager
level 2
local-user monitor
level 1
acl number 4999
rule 0 deny dest 0000-0000-0000 ffff-ffff-ffff
vlan 1
vlan 2
vlan 7
vlan 10
vlan 20
vlan 192
vlan 193
interface Vlan-interface1
ip address dhcp-alloc
interface Vlan-interface2
ip address 193.168.1.150 255.255.255.0
interface Vlan-interface10
interface Vlan-interface20
interface Aux1/0/0
interface Ethernet1/0/1
stp edged-port enable
broadcast-suppression PPS 500
priority trust
port access vlan 2
packet-filter inbound link-group 4999 rule 0
interface Ethernet1/0/2
priority trust
interface Ethernet1/0/3
priority trust
interface Ethernet1/0/4
priority trust
interface Ethernet1/0/5
priority trust
port access vlan 192
interface Ethernet1/0/6
priority trust
interface Ethernet1/0/7
priority trust
port access vlan 20
interface Ethernet1/0/8
priority trust
port access vlan 193
interface Ethernet1/0/9
priority trust
port access vlan 7
interface Ethernet1/0/10
priority trust
port access vlan 10
interface Ethernet1/0/11
port link-type trunk
port trunk permit vlan 1 7 10 20 192 to 193
priority trust
interface Ethernet1/0/12
priority trust
interface Ethernet1/0/13
priority trust
port access vlan 2
interface Ethernet1/0/14
priority trust
interface Ethernet1/0/15
priority trust
interface Ethernet1/0/16
priority trust
interface Ethernet1/0/17
priority trust
interface Ethernet1/0/18
priority trust
interface Ethernet1/0/19
duplex half
speed 10
priority trust
port isolate
interface Ethernet1/0/20
priority trust
interface Ethernet1/0/21
priority trust
port access vlan 7
interface Ethernet1/0/22
priority trust
port access vlan 10
interface Ethernet1/0/23
priority trust
interface Ethernet1/0/24
priority trust
interface GigabitEthernet1/0/25
flow-control
shutdown
interface GigabitEthernet1/0/26
shutdown
interface GigabitEthernet1/0/27
flow-control
interface GigabitEthernet1/0/28
sysname 4500
undo xrn-fabric authentication-mode
interface NULL0
ip route-static 192.168.1.0 255.255.255.0 192.168.1.70 preference 60
ip route-static 192.168.1.0 255.255.255.0 192.168.1.90 preference 60
ip route-static 192.168.1.0 255.255.255.0 192.168.1.60 preference 60
snmp-agent
snmp-agent local-engineid 8000002B0016E0CC55406877
snmp-agent community read public
snmp-agent community write private
snmp-agent sys-info version all
user-interface aux 0 7
authentication-mode scheme
user-interface vty 0 4
return
[4500]
If you already have your ports configured as access or trunk ports, then the main change would be the addition of the VLAN interfaces as follows:
interface vlan 2
no shut
interface vlan 10
no shut
ip address dhcp
interface vlan 20
no shut
ip address dhcp
Some additional commands that may be of use:
  • Use storm-control broadcast level pps 500 in place of broadcast-suppression PPS 500
  • Use spanning-tree portfast (on access ports) and spanning-tree portfast trunk (on trunk ports) in place of stp edged-port enable
