VLAN routing
yeow_km
i currently have a flat VLAN in my network.
there is not vlan in my switch.
all goes by 172.16.4.0/22.
network device starts from 172.16.4.0/22
servers start from 172.16.5.0/22
users start from 172.16.6.0/22.
users get dhcp address from my servers.
i am told to create vlan for new network setup.
1 VLAN for network
1 VLAN for server
2 VLAN for users.
how can i create 2 VLAN for my users if I do not want to change my dhcp scoping on the dhcp server.
Can i create 2 VLAN for my users ?
1 vlan for 172.16.6.0-50 and 2nd vlan for 172.126.6.100-150 ?
can this be done ?
8 Replies 8
Florin Barhala
Level 6
Level 6
Yes you can, just subnet close to power of 2 values: Range1: 172.16.6.0-63 then range 2: 172.16.6.0-64-127.
Yes you can if the switch supports but you'll have to change the dhcp server config and don't forget to use ip helper-address command otherwise the DHCP packets will never reach the server which is in a different vlan ( remember vlan is a broadcast domain and dhcp discover is broadcast).
Regards.
Alain.
i am using C3560G as core switch and C2960G as my access switch.
i know C3560 can do ip-helper but my boss does not want to change the dhcp server scoping.
i guess without changing the dhcp scoping, there is no point in creating 2 vlans for users as my environment is only less than 60 users.
Yes ,
you're right you can have only one user vlan and so let the scope as it is. But don't forget the ip helper-stuff.
Regards.
Alain
if I add another VLAN for voice, what are the things that I should take note ?
What do you mean by that?
Regards.
Alain.
You will need to create a new DHCP scope for Voice (dont forget to add dhcp option 150 for tftp server)
Create an SVI with, assign an Ip address to it from your newly created scope - this will be your default gateway
Use ip helper address command if needed
thats it
I think that change scopes on DHCP is best solution and not very complicated.
Try to explain it to your boss:)
Karel V.
