vlan routing
kishorebv
Community Member
This is kishore from india. my question is i have cyberoam CR1500ing firewall and CISCO SG500x switch and 3 wifi ruckus controllers. i have 2 type of ip address, Those are uration
1.172.16.10.1/21  - static ip
2.20.20.16.1/20- DHCP ip
Both ip addresses announced from cyberoam Lan zone. port 1 and port 2 both connected single cisco sg500x-24 port switch and i had a configuration dhcp ip and 3 ruckus controllers connected VLAN 100.
But by default dhcp announced by all ports in cisco sg500x switch.
now my question how disable a dhcp broadcast all ports in cisco sg500x?
5 Replies 5
Deepak Kumar
As the best practice, you need to configure two VLANs and assign the correct VLAN according to IP and users.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
thank u . why dhcp announce all ports by default but port under vlan 100?
Did you configured all ports under the VLAN 100 or assign IP helper address? If you not sure then share the running configuration.
Deepak Kumar
Deepak Kumar,
I am configure port 9-12 vlan 100 and remain all port default Vlan.
Please share configuration.
Deepak Kumar
Deepak Kumar,
