VLAN Shutdown not Working Cisco Packet Tracer 3560 Switch!
Sanjay1990
The Bold lines shows the issue where VLAN could not be shutdown on 3560 Switches in Packet Tracer!
Switch>en
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#vlan 30
Switch(config-vlan)#shutdown
% Invalid input detected at '^' marker.
Hello
L2 vlan shutdown not applicable in PT, due to its limited feature set.
Kind Regards
Paul
9 Replies 9
Hello
Kind Regards
Paul
Thank you for your prompt reply!
balaji.bandi
that is VLAN creation that means that is not interfaced.
if you like to shut down the VLAN 30 interface, the first check is the interface configured like the below command.
show interface vlan 30  (ot show ip interface brief) - if that is up and running and if  like to shutdown use below commands.
config t
interface vlan 30
shutdown
end
BB
Thank you for the alternative solution!
I just wanted to check the indirect causes that could bring an Interface down, like shutting down all the physical interfaces in that VLAN would also show a status of Down for that VLAN interface.
that is not an alternative solution, that is the right way to do shut and no shut interface, you can not shut VLAN directly with your command syntax.
if no device is connected to any Physical port part of the VLAN, the VLAN interface show by default shutdown mode. you need to have an active node or device for the VLAN SVI to come up.
BB
@balaji.bandi  not necessarily the svi will come up without any ports assigned to its vlan if that vlan is allowed over a trunk
Also you can shut a vlan down at L2 level
Kind Regards
Paul
yes maybe in the Physical kit or some other emulator/simulators  I do not believe this was the case with PT here, hence my suggestion was that.
- since I do not have any visibility on how the original post-user-configured, did he allowed the the vlan in PO config, so my comment was in generic.
Also you can shut a vlan down at L2 level   - you can not shutdown vlan1 any case here
BB
Sir!
As soon as I have access to a real switch I will definitely try to shutdown the VLAN, for test purpose.
Thank you!
Sir! As I am terrible while trying to explain something, I would like to let know that you are absolutely right about the Direct method of shutting down VLAN interface.
Thank you for your help. I was searching for alternative ways to bring an interface down.
Your post helped!
