Vlan Tagging Configuration for a Cisco 2960
mpippen01
I need some assistance configuring my Cisco 2960 Switch.
These are the VLan1 and Vlan41 settings.
•Ports 1-20 are U1 and T41
•Port 21 is U41
•Port 22 is U1, T41 and T42
•Port 23 is U42
•Port 24 is U1
PVID = 1
•U1(Untagged) is set on Vlan 1 in port configuration tab by setting the port field to U on every port 1-20.
•T41 (Tagged) is set on Vlan 41 in port configuration tab by setting the port field to T on every port 1-20.
Deepak Kumar
There is some missing information as VLAN 41 is for data or voice? If it voice then your switch configuration must be as:
Interface range gig1/0/1-20
switchport mode access
switchport access vlan 1
switchport voice vlan 41
spanningtree portfast
If VLAN 41 is not a voice VLAN then your configuration as like:
interface range gig 1/0/1-20
switchport mode trunk
switchport trunk allowed vlan 1,41
switch tunk native vlan 1
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
