Vlan traffic bandwidth restriction
r.robins
Hi All
Looking for some guidance on restricting bandwidth on a per vlan basis on either 3750 or 3560 switch.
We are soon going to have 8 vlans that are Layer 2 only and different contractors connected to each vlan.
From the switch we will have an uplink to an ASA and from there a connection to the internet.
We need to provide each contractor/vlan with bandwidth ranging from 256k to 2mb (bi directional) as they are going to pay for the bandwidth.
Any suggestions would be gratefully recieved.
gatlin007
Level 4
Level 4
You could use an aggregate policer on the 3750.  Each physical port that participates in the VLAN could be a participant of the aggregate policer; therefore the total bandwidth of all ports would never exceed the configured rate.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swqos.html#wp1048656
An easier approach may be to install a rate-limit on the ASA that matches the contractor netblock.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/qos.html#wp1065257
Chris
