VLAN Translation/Mapping and STP TCNs
Dennis Olvany
I configured vlan translation between vlan 2000 on a 6500 and vlan 1 on a 2950. I performed a packet capture to validate the configuration and basic ip connectivity seems good. I did, however, notice topology change notifications (stpFrames.txt attached). I see two frames over and over again: An stp frame from the 2950 and a tcn from the 6500. Looking at the spanning tree details (showSpann.txt attached), I see that the 2950 shows zero received bpdu.
Matthew Blanshard
Hey Dennis,
Is vlan 1 allowed across the trunk on the 6500?  Can you put in your configs?
-Matt
Here are the configs. Vlan 1 is not allowed on the 6500, but it seems that it should not be necessary. Since ip connectivity works, I would think it works equally for stp.
interface GigabitEthernet9/48
description uplink
no ip address
switchport
switchport trunk native vlan 50
switchport trunk allowed vlan 2000
switchport mode trunk
switchport nonegotiate
switchport vlan mapping enable
switchport vlan mapping 1 2000
end
interface FastEthernet0/4
description uplink
switchport trunk allowed vlan 1
end
