VLAN Trunking on LAN
dtuttle
Community Member
Hello Cisco Gurus
I am having an interesting, albeit, frustrating issue with interoperability between a 3560 48 Port Poe and an HP 5412zl backbone switch. I have 2 VLANS defined 1 is Data and 2 is voice. If I plug a PC and or phone into the HP directly I get a DHCP address for the phone and the PC.
I have a Gigabit uplink port set up
Untagged on the HP for VLAN 1 on the HP side. When I connect a computer to the Cisco switch I can get a computer to get an address but not a phone.
From the switch console I can ping both the computer and phone DHCP servers.
The uplink port is GB 0/1 and the port settings are as follows.
The IP subnet for the phones is 10.55.4.x/24
and data is 10.56.x.x /16
spanning-tree mode mst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
vlan 2
name Voice-vlan
interface FastEthernet0/1
switchport trunk allowed vlan 1,2
switchport mode trunk
switchport voice vlan 2
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust cos
auto qos voip trust
spanning-tree portfast
interface GigabitEthernet0/1
switchport trunk allowed vlan 1-2056
queue-set 2
mls qos trust cos
auto qos voip trust
I tried hard coding a PC using a 10.55.4.x address and I couldn't ping a thing. If I get a DHCP address on a PC I can ping both 10.55.4 and 10.56.x.x addresses. Its like the Cisco device is totally unaware of the existance of VLAN 2. Any ideas and or suggestions would be extremely helpful. This limitation is holding up a project already behind schedule. Thank you in advance for your feedback.
glen.grant
Don't know much about hp but on cisco user ports you do not need "switchport mode trunk" when you are using the switchport voice vlan option I believe. Try pulling that and see if it makes any difference. Don't think there should be any trunk parameters on the user port , someone correct me if I am wrong .
http://cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swvoip.html
Try with this conf:
int fast 0/1
switchport access vlan 2
Plug a PC in port 1 and look if it can contact the voice DHCP server.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/command/reference/cli3.html#wpmkr2561799
