vlans and trunks
goran ljubic
i created network like on picture that i attached in cisco packet tracer. i configured switchs but when i try pinging pc from vlan 2 fron one side to vlan 2 to second side pinging is not working why? where is mistake? i attached and configuration switches. i also  show commands for interfaces
switch 1
Switch#sh int fa0/2 status
% Invalid input detected at '^' marker.
switch 2
Switch#sh int fa0/3 status
why is displays those mesages?
ahmedshoaib
Level 4
Level 4
Hi;
As I see the configuration you swap the configuration of Switch2 F0/2 & F0/3.
As per topology F0/2 is connected to PC-2 of Vlan 3 & F0/3 is connected to PC-2 of Vlan 2.
While you configure F0/2 as a part of Vlan 2 & F0/3 is configure as a part of Vlan 3.
Swap the configuration and verify it.
Thanks & Best regards;
Leo Laohoo
Goran,
Kindly post this line of questioning in the Cisco Learning Network.
ahmedshoaib
Level 4
Level 4
Hi;
it's working, thanks
