VLANs not working between Cisco 1910 router and HP Procurve 2810 Switch
dneilson
I am trying to configure two subinterfaces on gigabitethernet0/1 on a Cisco 1910 router which is connected to an HP Procurve 2810 switch.  However, once I configure the two sub interfaces, no traffic will pass from either "sub" network to the router.  The two subinterfaces are gigabitethernet0/1.1 (ip address 172.16.96.2 255.255.240.0) and gigabitethernet0/1.2 (ip address 192.168.20.2 255.255.255.0).  When I connect a host to the switch with the ip address of 172.16.96.3, I can not even ping 172.16.96.2.  However, if I remove the two sub interfaces and configure gigabitethernet0/1 with an ip address 172.16.96.2 255.255.240.0, everything works great.
Here is a copy of the running-config on the Cisco 1921:
Current configuration : 2010 bytes
! Last configuration change at 19:07:06 pacific Fri Mar 9 1900
version 15.5
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname XXXXXXXXXX
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXX
enable password 7 XXXXXXXXXXXXXXXXXXXX
no aaa new-model
ethernet lmi ce
no process cpu extended history
no process cpu autoprofile hog
clock timezone pacific -8 0
clock summer-time PDT recurring
no ip source-route
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX154681DF
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.1.254 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 ip helper-address 172.16.96.5
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 encapsulation dot1Q 30
interface GigabitEthernet0/1.2
 encapsulation dot1Q 20
interface Serial0/0/0
 ip address 192.168.100.2 255.255.255.252
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 172.16.64.0 255.255.240.0 192.168.1.1
no service-routing capabilities-manager
snmp-server community WFFRead RO
snmp-server community DSIRead RO
snmp-server enable traps tty
access-list 100 permit ip any any
access-list 144 permit icmp host 172.16.96.3 host 172.16.96.2
access-list 144 permit icmp host 172.16.96.2 host 172.16.96.3
control-plane
line con 0
 exec-timeout 0 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp server 192.5.41.40
end
Here is the configuration of the HP Procurve switch:
; J9021A Configuration Editor; Created on release #N.11.75
hostname "Sterling SW1 ProCurve2810"
time timezone -480
no web-management
no telnet-server
ip default-gateway 172.16.96.2
sntp server 192.43.244.18
timesync sntp
sntp unicast
snmp-server community "public" Unrestricted
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-24
   ip address 172.16.16.70 255.255.240.0
   exit
vlan 20
   name "192.168.20"
   ip address 192.168.20.55 255.255.255.0
   tagged 1-24
   exit
vlan 30
   name "172.16.96"
   ip address 172.16.96.55 255.255.240.0
   tagged 1-24
   exit
ip ssh
password manager
Thanks in advance for any help you can provide.
Hitesh Vinzoda
Level 4
Level 4
Please make sure that port is configured as trunk on HP switch.
Hitesh
Richard Burts
I am not an expert on the Procurve switch but it seems to me that it is not right to have
vlan 1
untagged 1-24
vlan 20
tagged 1-24
vlan 30
tagged 1-24
Rick
Rick
Richard:
Thanks for taking the time to respond to my post.  Your response helped me go in the right direction (setting the switch port connected to the router as "tagged" (HP switch lingo for Cisco router "Trunk").
David
David
I am glad that my suggestion helped point you in the right direction.
Rick
Rick
Hitesh Vinzoda
Level 4
Level 4
Hitesh
