cisco catalyst 3640 read only file system
paul dungey
HI,
I have a customer switch that requires the configuration to be reset back to factory defaults but I'm getting a message,
Cisco Catalyst 3640 48 POE 4 x1G switch
File "flash:nvram_config" not deleted -- read only file system,
I've not come across this before so I would need a step by step support
output from switch
switch: dir flash:
Directory of flash:/
16161  drwx  4096       .
    2  drwx  4096       ..
16162  -rw-  79121160   cat3k_caa-base.SPA.03.03.03SE.pkg
16163  -rw-  6484668    cat3k_caa-drivers.SPA.03.03.03SE.pkg
16164  -rw-  34522096   cat3k_caa-infra.SPA.03.03.03SE.pkg
16165  -rw-  34821452   cat3k_caa-iosd-universalk9.SPA.150-1.EZ3.pkg
16166  -rw-  25131920   cat3k_caa-platform.SPA.03.03.03SE.pkg
16167  -rw-  77312832   cat3k_caa-wcm.SPA.10.1.130.0.pkg
16168  -rw-  1248       packages.conf
16169  -rw-  2097152    nvram_config
16170  -rw-  676        vlan.dat
1300365312 bytes available (287113216 bytes used)
switch: delete flash:nvram_config
Are you sure you want to delete "flash:nvram_config" (y/n)?y
switch:
Leo Laohoo
Let the switch boot naturally and then in enable mode, issue the command "wr erase" and this will factory default the appliance.
switch has booted up,
After powering up the cisco switch I'm faced with security banner and username to login,,
so pretty much in the same situation, is there a way to remove the flash files from read only to actually deleting them.
