vPC is down between cisco Nexus 3k and cisco Nexus 9k
cfchiang
From the image, we are actually add on two N9K switches.
1. We have chuck in the red cable and we try to configure VPC it showed error as port-channel110 is down (No operational members)
2. We have try another method not using VPC, We jus trunk it at both side switch ---> Then is ok, have no issue.
is both side Port-channel configuration.
N9K
interface port-channel110
switchport
switchport mode trunk
switchport trunk allowed vlan 461-468,1231-1233,1280-1283,2120-2121,2222
vpc 110
interface Ethernet1/29
switchport
channel-group 110 mode active
no shutdown
N3K
speed 40000
vpc 110
interface Ethernet1/51
8 Replies 8
balaji.bandi
is this config both the nexus9K and nexus3K identical ?
Looks some STP  issue, is the VLAN allowed in the vPC between nexus 9K and between 3K?
when you bring up port-channel 110 with vPC, can you check the logs on both the nexus ?
post below output from both the side ?
show vpc
show port-channel summary
show interface ethe 1/51 and 1/29 ?
BB
cfchiang
Dear Balaji,
Kindly find below attachment for output.
One side you have setup up speed of 40GB - other side not (may be worth adding and test it)
peer does not have corresponding vpc  - may be worth redoing the config, by putting the speed config again
what is the Logs show when you bring up the Port-channel between devices ?
BB
1. peer does not have corresponding vpc  - may be worth redoing the config, by putting the speed config again
Shall I re-setup the peer link?
2. what is the Logs show when you bring up the Port-channel between devices ?
How can i retrieve ya
Thank you.
not peer link, i mean port-channel 110 - recreate.
when you enabling port-channel 110 ( no shutdown)
look at the nexus 3K and 9K side below output see the logs
show logging last 50 (this show last 50lines ) - increase this to see more lines
BB
N9k
SW-NEXUS9K-1FC17-02(config-if)# show logging last 50
2022 Jan 19 17:09:25 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from none to Ethernet1/29
2022 Jan 19 17:09:25 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel110,bandwidth changed to 40000000 Kbit
2022 Jan 19 17:09:25 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_UP: Interface Ethernet1/29 is up in mode trunk
2022 Jan 19 17:09:25 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_UP: Interface port-channel110 is up in mode trunk
2022 Jan 19 17:09:33 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from Ethernet1/29 to none
2022 Jan 19 17:09:33 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2022 Jan 19 17:09:33 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: Ethernet1/29 is down
2022 Jan 19 17:09:33 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel110,bandwidth changed to 100000 Kbit
2022 Jan 19 17:09:33 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/29 is down (Link failure)
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-SPEED: Interface Ethernet1/29, operational speed changed to 40 Gbps
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/29, operational duplex mode changed to Full
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/29, operational Receive Flow Control state changed to off
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/29, operational Transmit Flow Control state changed to off
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-SPEED: Interface port-channel110, operational speed changed to 40 Gbps
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface port-channel110, operational duplex mode changed to Full
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel110, operational Receive Flow Control state changed to off
2022 Jan 19 17:09:34 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel110, operational Transmit Flow Control state changed to off
2022 Jan 19 17:09:37 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel110: Ethernet1/29 is up
2022 Jan 19 17:09:37 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from none to Ethernet1/29
2022 Jan 19 17:09:37 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel110,bandwidth changed to 40000000 Kbit
2022 Jan 19 17:09:37 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_UP: Interface Ethernet1/29 is up in mode trunk
2022 Jan 19 17:09:37 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_UP: Interface port-channel110 is up in mode trunk
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_NONE: Interface port-channel110 is down (None)
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from Ethernet1/29 to none
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: Ethernet1/29 is down
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel110,bandwidth changed to 100000 Kbit
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/29 is down(Config change)
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/29 is down (None)
2022 Jan 19 17:10:27 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-SPEED: Interface Ethernet1/29, operational speed changed to 40 Gbps
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/29, operational duplex mode changed to Full
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/29, operational Receive Flow Control state changed to off
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/29, operational Transmit Flow Control state changed to off
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-SPEED: Interface port-channel110, operational speed changed to 40 Gbps
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface port-channel110, operational duplex mode changed to Full
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel110, operational Receive Flow Control state changed to off
2022 Jan 19 17:10:29 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel110, operational Transmit Flow Control state changed to off
2022 Jan 19 17:13:09 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface port-channel110 is down(Config change)
2022 Jan 19 17:13:09 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members) (message repeated 2 ti
mes)
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-SPEED: Interface Ethernet1/29, operational speed changed to 40 Gbps
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/29, operational duplex mode changed to Full
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/29, operational Receive Flow Control state changed to off
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/29, operational Transmit Flow Control state changed to off
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-SPEED: Interface port-channel110, operational speed changed to 40 Gbps
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface port-channel110, operational duplex mode changed to Full
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel110, operational Receive Flow Control state changed to off
2022 Jan 19 17:14:03 SW-NEXUS9K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel110, operational Transmit Flow Control state changed to off
N3k
SW-NX3K-1FC17-02(config-if)# show logging last 50
2014 Jan 12 15:43:04 SW-NX3K-1FC17-02 last message repeated 1 time
2014 Jan 12 15:43:04 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: Ethernet1/51 is down
2014 Jan 12 15:43:04 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: port-channel110 is down
2014 Jan 12 15:43:04 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from Ethernet1/51 to none
2014 Jan 12 15:43:04 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2014 Jan 12 15:43:04 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/51 is down(Config change)
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 last message repeated 1 time
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-SPEED: Interface Ethernet1/51, operational speed changed to 40 Gbps
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/51, operational duplex mode changed to Full
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/51, operational Receive Flow Control state changed to off
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/51, operational Transmit Flow Control state changed to off
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-SPEED: Interface port-channel110, operational speed changed to 40 Gbps
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface port-channel110, operational duplex mode changed to Full
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel110, operational Receive Flow Control state changed to off
2014 Jan 12 15:43:06 SW-NX3K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel110, operational Transmit Flow Control state changed to off
2014 Jan 12 15:43:09 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel110: Ethernet1/51 is up
2014 Jan 12 15:43:09 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from none to Ethernet1/51
2014 Jan 12 15:43:09 SW-NX3K-1FC17-02 %ETHPORT-5-IF_UP: Interface Ethernet1/51 is up in mode trunk
2014 Jan 12 15:43:09 SW-NX3K-1FC17-02 %ETHPORT-5-IF_UP: Interface port-channel110 is up in mode trunk
2014 Jan 12 15:43:59 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from Ethernet1/51 to none
2014 Jan 12 15:43:59 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2014 Jan 12 15:43:59 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: Ethernet1/51 is down
2014 Jan 12 15:43:59 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: port-channel110 is down
2014 Jan 12 15:43:59 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/51 is down (Link failure)
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-SPEED: Interface Ethernet1/51, operational speed changed to 40 Gbps
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/51, operational duplex mode changed to Full
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/51, operational Receive Flow Control state changed to off
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/51, operational Transmit Flow Control state changed to off
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-SPEED: Interface port-channel110, operational speed changed to 40 Gbps
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface port-channel110, operational duplex mode changed to Full
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel110, operational Receive Flow Control state changed to off
2014 Jan 12 15:44:01 SW-NX3K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel110, operational Transmit Flow Control state changed to off
2014 Jan 12 15:44:04 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel110: Ethernet1/51 is up
2014 Jan 12 15:44:04 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel110: Ethernet1/51 is down
2014 Jan 12 15:44:04 SW-NX3K-1FC17-02 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel110: first operational port changed from Ethernet1/51 to none
2014 Jan 12 15:44:04 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2014 Jan 12 15:44:04 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/51 is down (Link failure)
2014 Jan 12 15:44:07 SW-NX3K-1FC17-02 last message repeated 1 time
2014 Jan 12 15:44:07 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/51 is down (None)
2014 Jan 12 15:44:07 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel110 is down (No operational members)
2014 Jan 12 15:47:33 SW-NX3K-1FC17-02 last message repeated 1 time
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-SPEED: Interface Ethernet1/51, operational speed changed to 40 Gbps
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/51, operational duplex mode changed to Full
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/51, operational Receive Flow Control state changed to off
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/51, operational Transmit Flow Control state changed to off
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-SPEED: Interface port-channel110, operational speed changed to 40 Gbps
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-IF_DUPLEX: Interface port-channel110, operational duplex mode changed to Full
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel110, operational Receive Flow Control state changed to off
2014 Jan 12 15:47:35 SW-NX3K-1FC17-02 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel110, operational Transmit Flow Control state changed to off
I have try re create int po 110. Still same issue.
Ethernet1/29 is down (vpc compatibility check failed)
where is the logs which was requested ?
BB
