vpc peer-keepalive link failure
sandevsingh
Hi, we are doing some acceptance testing in our environment before we put the nexus5ks in a vpc pair in production. Was curious to know, what will happen if the peer-keepalive-ink fails?
Edison Ortiz
Nothing happens if the peer-link remains up. If the peer-link fails, it won't come up until the peer-keepalive-link is also up.
Additionally, if the peer-link fails - there is no way to know each other status so traffic will be sent to both links.
The peer-keepalive-link is used to detect this kind of situation
ok great, is there a way to prempt the vpc domain primary switch back to active after a reboot? In other words, lets say i reboot n5k-A with the current vpc role of primary, the secondary obviously takes over the vpc primary role. BUT when n5k-A comes back up it stays as operational secondary. Would be good in troubleshooting situations.
No, there is only role priority and not preemption.
vPC does not support preemption.
The documentation contains all the information you need:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/interfaces/521_N11/b_5k_Interfaces_Config_Guide_Release_521N11_chapter_0101.html
Edison
Please remember to rate helpful posts.
