How can I tell both stack cables are connected?
Andy White
Level 3
Level 3
I have 2 remote 3570G switches that are stacked with 2 stack cables which I think gives me 32gb backbone.  Anyway how can I tell if both cables are connected as an engineer says he only saw one cable between the 2 onsite, but he can't be sure?
shillings
Level 4
Level 4
Enter  show switch stack-ring speed  and if the 'Stack Ring Configuration' says 'full' then the fully redundant cabling system is completed and forms the two counter-rotating 16Gbps rings. If it says 'half' then the engineer is correct and only one of the two stack cables is terminated between your pair of switches.
You can also enter  show switch stack-ports summary  and  show switch stack-ring activity detail  for more detailed information.
glen.grant
  Use the various  "show switch" commands and you will be able to see if the cables are plugged in and what the ring speed is .
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
sh switch stack-ring speed
sh switch stack-ports summary
