vpn split tunneling
carl_townshend
hi all, If I want a client to be able to connect to my office via vpn and also to the internet at home, do I need to do split tunneling and is this achieved on the client or do I need to do something on my pix ?
spremkumar
Level 9
Level 9
Hi Carl
You need to do the config accordingly in your PIX.
do refer this link for the same.
http://cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml
regds
so if we have a 0.0.0.0 0.0.0. route in there, all traffic goes out the tunnel, if I want to see other machines on my lan, so I need to start narrowing down the routes from the client rather than a default route, would this then allow me then to access internet at home ?
Sureshdank
Yes you need to configure on PIX, as well as you need to specify in your Client also.
You can just go through this link,
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml
Please rate the post.
Suresh Jain
