VRF issue with CLI 'no logging host '
oattoumani
Level 2
Level 2
I want to delete by CLI an VRF aware configuration, when i type "no logging host 10.1.1.1 vrf toto" the L3 switch says'ambigus command' but when I try with the cisco preconisations and type 'no logging host 10.1.1.1 ' there an other message 'logging host not found' and the command is not deleted, ever the ping 10.1.1.1 is OK.
IS it a bug (catalyst 4507R IOS 12.2.25EWA)or the an other plan to delete this command.
thanks bests regards
Omar
ajagadee
Omar,
What you are experiencing is a bug, documented in BUG ID CSCek33573.
Please refer the below release notes for details:
http://www.cisco.com/en/US/products/ps6021/prod_release_note09186a00807551fe.html
According to the release notes, the bug is fixed in 12.2(25)EWA6.
I hope the above information helps.
Arul
** Please rate all helpful posts **
ivillegas
Level 11
Level 11
The logging command identifies a syslog server host to receive logging messages. The host argument is the name or IP address of the host. By issuing this command more than once, you build a list of syslog servers that receive logging messages. The no logging command deletes the syslog server with the specified address from the list of syslogs.
ajagadee
Omar,
Arul
