Bookmark
Subscribe
333
VRF Links on Core Switch
Yannick Vranckx
Level 2
Level 2
Dear,
I have the following question:
Can i link 2 VRFs with each other on a 3850 core switch. Please note that the VRFs are extended across a MPLS to a router in a data center and are connected there.
So
Data Center Router ====> MPLS ====> Onsite Router ===> Core Switch ===> Access Switch
At this moment we have the problem that we run a Cisco unified comm client in the data center and IP phones in the LAN, Data & Voice are seperated in these VRFs and are ended at the Data center Router. So our media traffic for that client goes to far, i want to end it at the Core Switch. So can i already link the Data & Voice VRF there instead of at the Data Center?
I can always send you more detailed information
Kind Regards,
Yannick Vranckx
Reza Sharifi
Yes, you can use import and export maps to leak routes between the VRFs.
see link for examples:
https://rekrowten.wordpress.com/2012/09/24/route-leak-between-vrfs-with-import-maps-and-export-maps/
