VRF route leaking on Nexus 9k
Kenneth Goh
I am running GNS3, as shown in the diagram, how do I allow R1 in vrf RED to be able to ping to R2 int vrf BLUE?
Why are the no option to create route-target?
NXOS1(config)# vrf context RED
NXOS1(config-vrf)# address-family ipv4 unicast
NXOS1(config-vrf-af-ipv4)# ?
maximum Set a limit
no Negate a command or set its defaults
show Show running system information
end Go to exec mode
exit Exit from command interpreter
pop Pop mode from stack or restore from name
push Push current mode to stack or save it under name
where Shows the cli context you are in
NXOS1# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2019, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Nexus 9000v is a demo version of the Nexus Operating System
Software
BIOS: version
NXOS: version 9.3(1)
BIOS compile time:
NXOS image file is: bootflash:///nxos.9.3.1.bin
NXOS compile time: 7/18/2019 15:00:00 [07/19/2019 00:04:48]
Hardware
cisco Nexus9000 9000v Chassis
with 8060900 kB of memory.
Processor Board ID 9MIYLODKSQJ
Device name: NXOS1
bootflash: 3509454 kB
Kernel uptime is 0 day(s), 0 hour(s), 19 minute(s), 0 second(s)
Last reset
Reason: Unknown
System version:
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
NXOS1#
Hi @Kenneth Goh ,
Yes, you could do something like this.
vrf context Red
ip route 10.10.2.101/32 Ethernet1/2 10.10.2.101 vrf Blue
vrf context Blue
ip route 10.10.1.101/32 Ethernet1/1 10.10.1.101 vrf Red
11 Replies 11
Friend no need anything in NSK about VRF.
VRF is local known in R.
So router with VRF Red need staitc route using
Ip vrf Red (link between NSK and Router Blue VRF) next-hop NSK IP
And for router vrf Blue
Ip route vrf Blue (linke between NSK and Routrr vrf Red) next-hop NSK
Then try ping from router to router using
Pinf vrf (Red or Blue)
That it.
MHM
M02@rt37
Hello @Kenneth Goh
Try to configure first rd under your vrf context and after that see if RT command is available.
Best regards
balaji.bandi
reference document - https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/nx-os-software/213908-configure-vrf-route-leak-on-nexus.html
Harold Ritter
Hi @Kenneth Goh ,
You need to enable "feature bgp" to be able to configure the route target.
NXOS1(config)# feature bgp
NXOS1(config)# vrf context Red
export VRF export
import VRF import
maximum Set a limit
route-target Specify Target VPN Extended Communities
end Go to exec mode
Managed to create vrf below, can route leaking be done via only static routes?
vrf context BLUE
route-target import 1:1
route-target export 2:2
vrf context RED
route-target import 2:2
route-target export 1:1
interface Ethernet1/1
no switchport
vrf member RED
ip address 10.10.1.1/24
no shutdown
interface Ethernet1/2
no switchport
vrf member BLUE
ip address 10.10.2.1/24
no shutdown
no switchport
vrf member RED
no shutdown
no switchport
vrf member BLUE
no shutdown
Hi @Kenneth Goh ,
vrf context Red
vrf context Blue
Hi @Harold Ritter
There is no option to enter 'vrf'
NXOS1(config)# ip route 10.10.2.101/32 ethernet 1/2 ?
. Sub interface separator
/ Slash separator
A.B.C.D IP next-hop address in format i.i.i.i
NXOS1# show run
!Command: show running-config
!Running configuration last done at: Tue Dec 26 03:03:58 2023
!Time: Tue Dec 26 03:09:56 2023
version 10.1(1) Bios:version
hostname NXOS1
vdc NXOS1 id 1
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource u4route-mem minimum 248 maximum 248
limit-resource u6route-mem minimum 96 maximum 96
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
feature bgp
no password strength-check
username admin password 5 ! role network-admin
ip domain-lookup
copp profile strict
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
vlan 1
vrf context BLUE
vrf context RED
vrf context management
no switchport
vrf member RED
no shutdown
no switchport
vrf member BLUE
no shutdown
Hi @Kenneth Goh ,
Two things I noted.
You need to enter the next hop first as follow and then you will see the vrf option:
R1(config)# ip route 10.10.2.101/32 ethernet 1/2 10.10.2.101 ?
<CR>
<1-255> Route preference
*Default value is 1
name Specify name of the next hop
tag Supply tag value with static route
track Specify the Object to be Tracked
vrf VRF for next-hop if different from this vrf
The second thing is that the static route needs to be entered under the "vrf context" (Red or Blue), not under the global context.
Apologies, I managed to add the static routes under vrf context. Thanks for your help!
You are very welcome @Kenneth Goh and thanks for the feedback
If you enable vrf (need feature bgp sure in nexus) then you separate the RIB to two VRF'
You config vrf Red interface toward Router Red vrf
Config vef Blue interface toward Router Blue vrf
But here your ping will fialed
You need here since you separate the RIB vrf leaking
So you want to make
Vrf red
Route-target import 1:2
Vrf Blue
Route-target import 1:1
Route-target export 1:2
Then config bgp
Address family ipv4 Red
Redistrubte direct
Address family ipv4 Blue
Redistrubte Blue
Then your ping success
MHM
