VRRP on Nexus pair not working correctly
Frank Hoeben
Setup:
2x Nexus 5672UP
NX-OS version 7.0
vPC seems to be operational (via 2x 40gb link).
However the VRRP links I have created show as master on both sides (with the accompanying error message in the logs).
I must be forgetting something.
interface Vlan19
  description Switches
  no shutdown
  vrf member standaard
  ip address 10.0.19.253/24
  ip dhcp relay address 10.0.10.7
  vrrp 19
    priority 120
    authentication text password
    address 10.0.19.254
    no shutdown
interface Vlan19
  no shutdown
  ip address 10.0.19.252/24
  vrrp 19
    address 10.0.19.254
    no shutdown
Switch-01# sh vrrp
      Interface  VR IpVersion Pri   Time Pre State   VR IP addr
         Vlan10  10   IPV4    100    1 s  Y  Master  10.0.10.254
         Vlan19  19   IPV4    100    1 s  Y  Master  10.0.19.254
         Vlan21  21   IPV4    100    1 s  Y  Master  10.0.21.254
         Vlan40  40   IPV4    100    1 s  Y  Master  10.0.99.254
         Vlan55  55   IPV4    100    1 s  Y  Master  10.0.55.254
         Vlan56  56   IPV4    100    1 s  Y  Master  10.0.56.254
         Vlan57  57   IPV4    100    1 s  Y  Master  10.0.57.254
2015 Sep 16 15:56:24 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
137 on Vlan55(port-channel1000) is duplicate of local virtual ip, 10.0.55.254
2015 Sep 16 15:56:34 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
10a on Vlan10(port-channel1000) is duplicate of local virtual ip, 10.0.10.254
2015 Sep 16 15:56:44 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
128 on Vlan40(port-channel1000) is duplicate of local virtual ip, 10.0.99.254
2015 Sep 16 15:56:54 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
113 on Vlan19(port-channel1000) is duplicate of local virtual ip, 10.0.19.254
2015 Sep 16 15:57:05 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
138 on Vlan56(port-channel1000) is duplicate of local virtual ip, 10.0.56.254
2015 Sep 16 15:57:16 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
2015 Sep 16 15:57:26 NH1816-NO2 %ARP-3-DUP_VADDR_SRC_IP:  arp [3760]  Source address of packet received from 0000.5e00.0
Switch-01# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 100
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 0
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
vPC Peer-link status
id   Port   Status Active vlans
1    Po1000 up     1,10-11,19-21,40-41,55-57
Reza Sharifi
What port is your VPC peer link?
Have you allowed all vlans on that link?
I have connected ports E2/5 and E2/6 in channel group 1000 with vPC domain 100.
There are no restrictions placed on vlans in the vPV config, nor are there any access-lists active.
I've also tried hsrp instead of vrrp, which had the same problem.
So I'm fairly sure it's got something to do with the vPC config
