VSS implementation
abeid
We are having 12.2(33)-SXH2a on our cisco 6500 chassis and we are trying to implement VSS. We want to use layer-3 dual active detection using BFD but the command to exclude the BFD interface from shutting down during the dual active detection is not accepting and it is giving an error message saying " Cannot configure exclution on dual active interfaces ". So can anyone help me out with this ?
tstanik
Level 9
Level 9
This command will not support for the layer-3 dual active detection.
Can any one Help me out with the Service Modules VSS is going to support in the later releases like 12.2(33)-SXI .If there is a link where i can check, would be much more helpful.
Thanks Guys, in advance
FYI.. 12.2(33)SXI for the Catalyst 6500 has been posted on cisco.com. Below is the release notes which should answer most of your questions.
Cisco IOS Software Release 12.2(33)SXI, New Features and Hardware Support
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6970/ps6017/ps9673/product_bulletin_c25-503086.html
Arul
*Pls rate if it helps*
