Virtual switch 6509
funyphong
Community Member
When I converted my switchs(6509E) to virtual mode , my service modules were powered down, I tried to use command " power enable " but not active. Pls tell me how turn on
9 Replies 9
dipjitsengupta
Community Member
hi,
pls tell me which IOS u have in that 6509E switch???
CORE1#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-VM), Versi on 12.2(33)SXH1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 17-Jan-08 08:09 by prod_rel_team
Hi, the 12.2(33)-SXH1 version doesnt support any service modules apart from NAM-1,2. It is in the pipeline to support more service modules in future release 12.2-SXI.
Hi!
You are using a VSS there? Do a show module and paste here the results.
In case you are using VSS,
do the following:
sh platform hardware pfc mode
PFC operating mode : (tell us what is displayed here)
If modules are installed in a system that contains a DFC3C, then the module may never be allowed to power up.
Cheers,
Calin
CORE1#show module
Mod Ports Card Type
Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1213KKAY
2 6 Firewall Module WS-SVC-FWM-1 SAD121204LJ
3 1 Application Control Engine Module ACE20-MOD-K9 SAD1212020S
4 8 Intrusion Detection System WS-SVC-IDSM-2 SAD120907H9
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G SAL1213K85Z
Mod MAC addresses Hw Fw Sw Status
1 001f.9e3d.d800 to 001f.9e3d.d82f 2.7 12.2(14r)S5 12.2(33)SXH1 Ok
2 001f.6c89.112a to 001f.6c89.1131 4.2 Unknown Unknown PwrDown
3 001f.9e1a.e9b8 to 001f.9e1a.e9bf 2.3 Unknown Unknown PwrDown
4 001f.9e1a.c238 to 001f.9e1a.c23f 6.3 Unknown Unknown PwrDown
5 001e.7a58.5f40 to 001e.7a58.5f47 2.0 8.5(2) 12.2(33)SXH1 Ok
CORE1#show platform hardware pfc mode
PFC operating mode : PFC3C
Configured PFC operating mode : None
CORE1#show module
Mod Ports Card Type
Model Serial No.
Here is what you were asking :
rtr-sem-dc#sh platform hardware pfc mode
rtr-sem-dc#
Kind Regards,
Pierre-Louis
Ryan Carretta
Your question was already answered in this thread:
The service modules you have aren't supported with VSS quite yet. VSS support for ACE10, ACE20, FWSM, IDSM, and WiSM will come with the 12.2(33)SXI code release.
-Ryan
ajagadee
FYI.. 12.2(33)SXI for the Catalyst 6500 has been posted on cisco.com and this version of software does support FWSM with VSS.
Release Notes for the Catalyst 6500 Series and Cisco 7600 Series Firewall Services Module, 4.0(x)
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/release/notes/fwsmrn40.html
Arul
*Pls rate if it helps*
