VSS interfaces on 4500x
WILLIAM STEGMAN
Level 4
Level 4
How would I be able to determine which switch a physical interface is tied to from the CLI?  In other words, I'm sitting at the prompt on the active 4500x and need to setup one port on one of the switches. How do I know which switch hosts the interface on 1/1/1?
If I'm sitting next to the 4500x, I can see the  MAC address of the switch on a factory label, but of course I won't always be next to it, and show module displays both switches as module 1.  And sh switch virtual doesn't give me much to go on either.
thank you
PSQ_4500X_VSS#sh module 1
Mod Ports Card Type                              Model              Serial No.
 1    32  4500X-32 10GE (SFP+)                   WS-C4500X-32       JAE191801HP
 M MAC addresses                    Hw  Fw           Sw               Status
 1 78ba.f985.1e80 to 78ba.f985.1e9f 2.0 15.0(1r)SG10 03.04.06.SG      Ok
PSQ_4500X_VSS#sh module 2
% Module 2 not present.
PSQ_4500X_VSS#sh module all
Switch Number: 1 Role: Virtual Switch Active
Chassis Type : WS-C4500X-32
Mod  Redundancy role     Operating mode      Redundancy status
 1   Active Supervisor   SSO                 Active
System Failures:
Power Supply:   bad/off (see 'show power')
Switch Number: 2 Role: Virtual Switch Standby
Power consumed by backplane : 0 Watts
 1    32  4500X-32 10GE (SFP+)                   WS-C4500X-32       JAE191801CY
 1 78ba.f985.22c0 to 78ba.f985.22df 2.0 15.0(1r)SG11 03.04.06.SG      Ok
 1   Standby Supervisor  SSO                 Standby hot
InayathUlla Sharieff
https://supportforums.cisco.com/document/124626/virtual-switching-system-vss-configuration-cisco-4500-series-switches#Configuration_Steps
interface-type switch-number/slot/port"
Example:-
starting letter "1/2" indicates the VSS 1 primary and 2 is secondary.
VSS 1st device uses 1/1/2 and for module 4 example : 1/4/1-- 1 is the active, 4/1 is the interface of module 4.
VSS 2nd device starts with letter 2. ( 2/1/1-- secondary chasis module 1 port 1).
regards
Inayath
***********Please do not forget to rate if this info is helpfull********
Example:-
regards
Inayath
that helps Inayath.   I can run a sh virtual switch role and see the switch ID (1 or 2) of the active sup, and the run a sh module that displays the MAC address of the active sup and have the local contact look at the mac address on the switch's label to determine which switch to connect an uplink.
thank you
Switch  Switch Status  Preempt       Priority  Role     Local   Remote
        Number         Oper(Conf)    Oper(Conf)         SID     SID
LOCAL   2      UP      FALSE(N )     100(100)  ACTIVE   0       0
REMOTE  1      UP      FALSE(N )     100(100)  STANDBY  7387    8259
sh module
