VSS - not able to set switch number
rhub
Hi all
I have a 6509-E chassis that was prevoius in a VSS configuration. Due to some VSL failures I had to cobvert it to a standalone chassis but would like to bring it back to a virtual system.
Whenever I try to convert it by using the command "switch convert mode virtual" I get the msg %Please configure local switch number first". After doing so by entering the CLI cmd "switch set switch_num 1 local" I still get the same message.
Any hints or tipps are very much appreciated
Regards Roman
Leo Laohoo
Duplicate post #1.
