vss quad-sup with sup 2T
m.arancibia
Hi everybody,
I have configured 2 6509E chassis with two 2T supervisors in each chassis. We are using de IOS version 15.1(1)SY.
We have a VSL with 2 TenGig interfaces.
After to apply the command : switch convert mode virtual , the Sup Standby in each chassis become to ROMMON mode.
When I connect to the console of sup (rommon) and apply the command boot, it received this message:
System detected Virtual Switch configuration...
Interface TenGigabitEthernet 2/5/4 is member of PortChannel 20
Interface TenGigabitEthernet 2/5/5 is member of PortChannel 20
Firmware compiled 11-Sep-12 14:49 by integ Build [26624]
*Apr 25 19:43:44.747: %PFREDUN-4-SUP_FORCE_TO_ROMMON: Supervisor forced to rommon with reason: In-chassis Standby is not supported in this version
Resetting .......
I try introducing the command : switch virtual in-chassis standby switch 1 enable; and after that I try to boot the sup(rommon) but the result is exactly the same.
Please, I need to know if is necessary to change to another IOS version or introduce another adicional configuration.
Config Applied:
switch virtual domain 100
switch mode virtual
interface Port-channel10
no switchport
no ip address
no platform qos channel-consistency
switch virtual link 1
interface Port-channel20
no switchport
no ip address
switch virtual link 2
interface TenGigabitEthernet1/5/4
no switchport
no ip address
no cdp enable
channel-group 10 mode on
interface TenGigabitEthernet1/5/5
no switchport
no ip address
no cdp enable
interface TenGigabitEthernet2/5/4
no switchport
no ip address
no cdp enable
channel-group 20 mode on
interface TenGigabitEthernet2/5/5
no switchport
no ip address
no cdp enable
Best Regards
19 Replies 19
I am going to upgrade to 15-1(2) as it is now safe harbour code and report back. The boot process for the rommon decompresses the image, resets, and goes back to rommon.
The version I am running - 151-1.SY is not supported for quad supervisors; 151-1.SY1 is; I am hoping 151-2.SY is supported. Will confirm when I have everything upgraded
Right..
I mentioned that in the previous post quad-sup2t is supported on and after 15.1.(1)SY1.
Regards.
Wilson B
151-2.SY works and the issue is corrected! Thank you!
glad to hear that;)
Wilson B
