VSS SNMP Monitoring
routercpu
I have two 6509E's configured with VSS.  In this configuration, is it possible to monitor the CPU and memory of each switch independently using SNMP?
chris.atkinson
The answer appears to be "almost".... IOS: 12.2(33)SXI10
=== Typical Router 5-min Avg CPU ===
# snmpwalk -v 2c -c 172.16.X.X 1.3.6.1.4.1.9.2.1.58.0
SNMPv2-SMI::enterprises.9.2.1.58.0 = INTEGER: 11
=== Multi-CPU 5-min Avg ===
# snmpwalk -v 2c -c 172.16.X.X 1.3.6.1.4.1.9.9.109.1.1.1.1.8
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.1 = Gauge32: 11
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.2 = Gauge32: 17
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.3 = Gauge32: 2
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.4 = Gauge32: 11
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.5 = Gauge32: 2
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.6 = Gauge32: 5
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.7 = Gauge32: 5
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.10 = Gauge32: 11
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.11 = Gauge32: 5
# snmpwalk -v 2c -c 172.16.X.X 1.3.6.1.4.1.9.9.109.1.1.1.1.2
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.1 = INTEGER: 1014
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.2 = INTEGER: 1001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.3 = INTEGER: 6001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.4 = INTEGER: 2001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.5 = INTEGER: 5001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.6 = INTEGER: 3001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.7 = INTEGER: 4001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.10 = INTEGER: 10001
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.2.11 = INTEGER: 9001
# snmpwalk -v 2c -c 172.16.X.X .1.3.6.1.2.1.47.1.1.1.1.7.1014
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1014 = STRING: "Chassis 1 CPU of Routing Processor 5"
# snmpwalk -v 2c -c 172.16.X.X .1.3.6.1.2.1.47.1.1.1.1.7.1001
SNMPv2-SMI::mib-2.47.1.1.1.1.7.1001 = STRING: "Chassis 1 CPU of Switching Processor 5"
# snmpwalk -v 2c -c 172.16.X.X .1.3.6.1.2.1.47.1.1.1.1.7.8014
SNMPv2-SMI::mib-2.47.1.1.1.1.7.8014 = STRING: "Chassis 2 CPU of Routing Processor 5"
# snmpwalk -v 2c -c 172.16.X.X .1.3.6.1.2.1.47.1.1.1.1.7.8001
SNMPv2-SMI::mib-2.47.1.1.1.1.7.8001 = STRING: "Chassis 2 CPU of Switching Processor 5"
