VSS SYNCHRONIZAION ISSUE WITH C6807 CISCO SWITCH
Muhammadnawaz
Hi everyone,
I have an issue while configuring the VSS on C6807 switches. can anyone please help and guide me how to solve this issue, Switch A&B configurations are not getting synched  its not working as a single unit.  please help...
CORESW-A
LAN-CORE-SW-A#show module
Mod Ports Card Type Model Serial No.
1 20 DCEF2T 4 port 40GE / 16 port 10GE C6800-16P10G JAE23511B2V
3 20 Supervisor Engine 6T 10GE w/ CTS (Hot) C6800-SUP6T JAE235122N0
4 20 Supervisor Engine 6T 10GE w/ CTS (Acti C6800-SUP6T JAE24021GUL
Mod MAC addresses Hw Fw Sw Status
1 6c31.0ec8.0f7c to 6c31.0ec8.0f8f 2.2 15.2(1r)SYL3 15.5(1)SY4 Ok
3 c4b2.39bb.98fa to c4b2.39bb.9908 2.1 15.3(04r)SYS 15.5(1)SY4 Ok
4 c4b2.39bb.9cba to c4b2.39bb.9cc8 2.1 15.3(04r)SYS 15.5(1)SY4 Ok
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card C6800-DFC JAE23511B2V 2.2 Ok
3 Policy Feature Card 4 C6800-PFC JAE23511QEB 1.0 Ok
4 Policy Feature Card 4 C6800-PFC JAE24021D6D 1.0 Ok
Mod Online Diag Status
1 Pass
3 Pass
LAN-CORE-SW-A#show switch virtual
Switch Mode : Standalone
Not in Virtual Switch mode due to:
Domain ID is not configured
When I tried to save config on switch A.
startup-config file open failed (Resource temporarily unavailable)
 CORESW-B
LAN_CORE_SW#show module
1 20 DCEF2T 4 port 40GE / 16 port 10GE C6800-16P10G JAE23511B2T
3 20 Supervisor Engine 6T 10GE w/ CTS (Acti C6800-SUP6T JAE234908WJ
4 20 Supervisor Engine 6T 10GE w/ CTS (CSSO C6800-SUP6T JAE24021GW9
1 6c31.0ec8.0ef0 to 6c31.0ec8.0f03 2.2 15.2(1r)SYL3 15.5(1)SY4 Ok
3 a0b4.390b.8c61 to a0b4.390b.8c6f 2.1 15.3(04r)SYS 15.5(1)SY4 Ok
4 c4b2.39bb.9ce7 to c4b2.39bb.9cf5 2.1 15.3(04r)SYS 15.5(1)SY4 Ok
1 Distributed Forwarding Card C6800-DFC JAE23511B2T 2.2 Ok
3 Policy Feature Card 4 C6800-PFC JAE23420U99 1.0 Ok
4 Policy Feature Card 4 C6800-PFC JAE24021D4J 1.0 Ok
1 Pass
3 Minor Error
4 Minor Error
LAN_CORE_SW#show version
Cisco IOS Software, s6t64 Software (s6t64-ADVENTERPRISEK9_NPE-M), Version 15.5(1)SY4, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Mon 02-Sep-19 08:40 by prod_rel_team
ROM: System Bootstrap, Version 15.3(04r)SYS, RELEASE SOFTWARE
LAN_CORE_SW uptime is 4 hours, 34 minutes
Uptime for this control processor is 4 hours, 37 minutes
System restarted at 08:04:50 UTC Sun Nov 27 2022
System image file is "bootdisk:s6t64-adventerprisek9_npe-mz.SPA.155-1.SY4.bin"
Last reload reason: power-on
5 Replies 5
Leo Laohoo
@Muhammadnawaz wrote:
3 Minor Error
4 Minor Error
I know the reason why Switch B line cards are suspended.
Starting from 15.5(1)SY4 some line cards need to have an FPGA Upgrade.  With previous versions, the FPGA upgrade was automatic, however, starting with15.5(1)SY4 the FPGA needs to be manually.
To make sure people suffer, the document about FPGA Upgrade is hidden:  Performing FPGA Upgrade
If anyone think it does not get any worse then this, then sit down for the punch-line:  The command is "GOLD" is a hidden command.
For VSS case:
Device# upgrade winters-flash switch switch-number slot slot-number bundled-image GOLD
For non-VSS case:
Device# upgrade winters-flash slot slot-number bundled-image GOLD
Hi Leo,
thanks for the comments on the post, issue is still there, I tried to follow these steps mentioned above, but same issue I have been facing.
Even whaen I tried to save the configurations following error we found
startup-config file open failed Resource temporarily unavailable
Are you consoled into both supervisor cards?
The only way to update the FPGA is by console (because they are not working).
Hi Leo,
please have a look at the below output of C6807 switch when I run the below command to convert the switch in virtual mode while in configuration of VSS, following out I see
Router#switch convert mode virtual
This command will convert all interface names
to naming convention "interface-type switch-number/slot/port",
save the running config to startup-config and
reload the switch.
NOTE: Make sure to configure one or more dual-active detection methods
once the conversion is complete and the switches have come up in VSS mode.
Do you want to proceed? [yes/no]: yes
Converting int
*Jan 3 15:54:05.923: %SYS-5-RELOAD: Reload requested by Exec. Reload Reason: Conversion.erface namesstartup-config file open failed (Resource temporarily unavailable)
Saving converted configuration to bootdisk: ...
%% Non-volatile configuration memory invalid or not presentIf the CLI command 'erase /all nvram:' has not been run or did not complete successfully, please run 'erase /all nvram:' to re-format the device.
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Sup6t Boot Rom :Upgradable Region
Last reset cause: Software Reset, reset code 0x4
Sup6t platform with 4194304 Kbytes of main memory
rommon 1 >
rommon 1 > boot
#Booting s6t64-adventerprisek9_npe-mz.SPA.155-1.SY4.bin ...
ELF image verification PASSED
Self extracting the image... [OK]
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################ [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Warning: The nvram is either corrupted or uninitialized. Initialize the nvram by executing the command 'erase /all nvram:' after bootup.
This is a VSS capable switch.
VSL ports can be configured in slot: 3
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE ?SOFTWARE?),
USING SUCH SOFTWARE, AND/OR ACTIVATION OF THE SOFTWARE COMMAND LINE INTERFACE
CONSTITUTES YOUR FULL ACCEPTANCE OF THE FOLLOWING TERMS.YOU MUST NOT PROCEED
FURTHER IF YOU ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement (EULA)
and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are licensed
for a particular term, that the license to such Software and/or features is valid only
for the applicable term and that such Software and/or features may be shut down or
otherwise terminated by Cisco after expiration of the applicable license term (e.g.,
90-day trial period). Cisco reserves the right to terminate any such Software feature
electronically or by any other means available. While Cisco may provide alerts, it is
your sole responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the Software feature.
To memorialize your acceptance of these terms and activate your license to use the Software,
please execute the command "license accept end user agreement force".
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
USB high speed device - Port:0
Cisco C6807-XL ( Intel(R) Core(TM) i3-3227U CPU @ 2.50GHz ) processor (revision ) with 2879440K/524288K bytes of memory.
Processor board ID FGE23416478
Processor signature 0xA9060300
Last reset from s/w reset
1 Virtual Ethernet interface
1 Gigabit Ethernet interface
32 Ten Gigabit Ethernet interfaces
4 Forty Gigabit Ethernet interfaces
3735536K bytes of USB Flash bootdisk (Read/Write)
SETUP: new interface TenGigabitEthernet1/1 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/2 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/3 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/4 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/5 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/6 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/7 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/8 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/9 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/10 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/11 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/12 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/13 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/14 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/15 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet1/16 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/1 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/2 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/3 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/4 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/5 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/6 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/7 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet3/8 placed in "shutdown" state
SETUP: new interface FortyGigabitEthernet3/9 placed in "shutdown" state
SETUP: new interface FortyGigabitEthernet3/10 placed in "shutdown" state
SETUP: new interface mgmt0 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/1 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/2 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/3 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/4 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/5 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/6 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/7 placed in "shutdown" state
SETUP: new interface TenGigabitEthernet4/8 placed in "shutdown" state
SETUP: new interface FortyGigabitEthernet4/9 placed in "shutdown" state
SETUP: new interface FortyGigabitEthernet4/10 placed in "shutdown" state
SETUP: new interface Vlan1 placed in "shutdown" state
Press RETURN to get started!
*Mar 1 00:00:02.535: %PRST_IFS-3-GENERAL: persistent media IFS general error: Open Read - can't open nvram:persistent-data errno is 11
*Jan 3 15:58:45.003: %VS_PARSE-3-MISMATCH: Unable to open STARTUP-CONFIG
*Jan 3 15:58:45.003: %KEYSTORE-3-IFS_OPEN_R: Failed to open file "nvram:/private-KS1" for reading software keystore. (Resource temporarily unavailable)
Firmware compiled 02-Sep-19 08:39 by binugopa Build [26112]
*Jan 3 15:59:27.923: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
*Jan 3 15:59:33.211: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table Resource temporarily unavailable
*Jan 3 15:59:33.219: ACT2 Library Version: 1.3.2
*Jan 3 15:59:48.331: %C6K_PLATFORM-4-CONFREG_BREAK_ENABLED: The default factory setting for config register is 0x2102.It is advisable to retain 1 in 0x2102 as it prevents returning to ROMMON when break is issued.
*Jan 3 15:59:54.095: %USBFLASH-5-CHANGE: bootdisk has been inserted!
*Jan 3 15:59:54.095: %USBFLASH-5-CHANGE: bootdisk Initialization in progress. Do not remove until initialization complete.
*Jan 3 16:00:17.887: %USBFLASH-5-CHANGE: bootdisk Initialization complete.
*Jan 3 16:00:24.563: %SYS-5-RESTART: System restarted --
*Jan 3 16:00:24.779: %SYS-6-BOOTTIME: Time taken to reboot after reload = 390 seconds
*Jan 3 16:00:25.563: %CPU_MONITOR-6-RECORRECT_TIMER_COUNT: Recurring Timer Count: 1
*Jan 3 16:00:25.899: %OIR-6-INSPS: Power supply inserted in slot 1
*Jan 3 16:00:25.927: %C6KPWR-4-PSOK: power supply 1 turned on.
*Jan 3 16:00:26.363: %OIR-6-INSPS: Power supply inserted in slot 2
*Jan 3 16:00:26.391: %C6KPWR-4-PSOK: power supply 2 turned on.
*Jan 3 16:00:28.223: %OIR-6-INSPC: Power converter inserted in slot 1
*Jan 3 16:00:29.079: %OIR-6-INSPC: Power converter inserted in slot 2
*Jan 3 16:00:29.167: %C6KENV-4-FANHPMODE: Fan-tray 1 is operating in high power mode
*Jan 3 16:00:30.855: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Jan 3 16:00:34.111: %FABRIC-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 3 became active.
*Jan 3 16:00:40.059: %PRST_VBL-3-GENERAL: Persistent general error: 4 consecutive flushes failed, giving up
*Jan 3 16:00:46.543: %DIAG-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
*Jan 3 16:01:26.767: %DIAG-6-DIAG_OK: Module 3: Passed Online Diagnostics
*Jan 3 16:01:27.383: %C6KENV-4-LOWER_SLOT_EMPTY: The lower adjacent slot of module 3 might be empty. Airdam must be installed in that slot to be NEBS compliant
*Jan 3 16:01:29.631: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jan 3 16:01:30.551: %OIR-6-SP_INSCARD: Card inserted in slot 3, interfaces are now online
*Jan 3 16:01:37.399: %PRST_VBL-3-GENERAL: Persistent general error: 4 consecutive flushes failed, giving up
Firmware compiled 02-Sep-19 08:38 by binugopa Build [26880]
Initializing and starting the background process
Jan 1 00:00:19.443: %C6K_PLATFORM-DFC1-2-CRITICAL_FPGA_UPGRADE:
************************ !! UPDATE REQUIRED !! ************************
Critical firmware upgrade available for Module: 1.
Please refer Software release documentation for more information.
Jan 1 00:00:44.039: DFC1: Currently running ROMMON from S (Gold) region
Jan 1 00:00:45.123: %SYS-DFC1-5-RESTART: System restarted --
Cisco IOS Software, c4lc_s6t Software (c4lc_s6t-SP-M), Version 15.5(1)SY4, RELEASE SOFTWARE (fc4)
Compiled Mon 02-Sep-19 08:38 by prod_rel_team
now online
Router>
Router>
Router>
Router>en
Router#sh
Router#show inter
Router#show interfaces des
Router#show interfaces description
Interface Status Protocol Description
Te1/1 admin down down
Te1/2 admin down down
Te1/3 admin down down
Te1/4 admin down down
Te1/5 admin down down
Te1/6 admin down down
Te1/7 admin down down
Te1/8 admin down down
Te1/9 admin down down
Te1/10 admin down down
Te1/11 admin down down
Te1/12 admin down down
Te1/13 admin down down
Te1/14 admin down down
Te1/15 admin down down
Te1/16 admin down down
Te3/1 admin down down
Te3/2 admin down down
Te3/3 admin down down
Te3/4 admin down down
Te3/5 admin down down
Te3/6 admin down down
Te3/7 admin down down
Te3/8 admin down down
Fo3/9 admin down down
Fo3/10 admin down down
mgmt0 admin down down
Te4/1 admin down down
Te4/2 admin down down
Te4/3 admin down down
Te4/4 admin down down
Te4/5 admin down down
Te4/6 admin down down
Te4/7 admin down down
Te4/8 admin down down
Fo4/9 admin down down
Fo4/10 admin down down
Vl1 admin down down
Router#
Router#
Router#
Router#wr
Router#
Router#
Router#
What, exactly, am I suppose to be looking at?
The logs above points to what I have said about FPGA upgrade.
