VSS using just three (3) Supervisors
ALISSON CHAGAS
Hi ,
I have a customer that has a Catalyst 6509 with two Supervisor VSS capable and my Sales team sell another 6509 with just one Supervisor VSS capable. Simple question: Will VSS configuration will recognize that I have three Supervisors? It will work as QUAD-SUP solution or as a normal VSS solution? Thanks in advance.
7 Replies 7
Reza Sharifi
It will work as normal VSS with one sup in each 6500
I recommend you do not use the second sup at all until you have 4 sups and the IOS that supports them
Currently the IOS for quad sup is not available anyway
Hi Sharifi.
I've already implemented a VSS solution with quad-sup (two on each chassis) using this IOS version:
s72033-ipbasek9-mz.122-33.SXI4a.bin and it worked fine.
My doubt is about how it will work with two SUP at one chassis and just one at the other.
Mohamed Sobair
Level 7
Level 7
At this stage VSS can Only be supported by Two SUPs in two different chassis. As pointed by Riza , the Quad Sup might be in the roadmap but it's not supported.
Mohamed
Hi Sobair,
As what everyone has pointed out:  This setup will NOT work.
SUP 720 with IOS 12.x support quad-SUP
SUP2T requires 15.1.x to run quad-sup which is a roadmap
agree with others this is not a good combination to work with, however i can not confirm it won't work you can try it may the chassis with 2x SUPs utilize the secondary SUP in case of the ICA failure you need to test it assuming your HW and SW support quad-sup !
hope this help
Hi Marwanshawi,
I agree with you, It's not a good combination, this is why I'm in doubt how it will work, and at this time I cannot make any previous test, just during the maintenance window.
