VSS - WS-C4506-E Catalyst 4500 UNIVERSALK9-M
inteldarvid
hi team
Good day.
Could you help me please, I have some doubts with the update of the version for Catalyst 4500 that we have in the company.
I want to update the version to the recommended version of cisco. Can you recommend the steps to update a vss. For example I have the following commands:
I was going through the below cisco document and there are a few more steps as below: Is it necessary?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1169328
Router(config)# no boot system
Router(config)# config-register 0x2102
Router(config)# boot system flash disk0:image_name
Router(config)# end
Router# copy running-config startup-config
Router# redundancy reload peer
Router# redundancy force-switchover
Do you also recommend me to update the rommon?
I attach switch data:
VWARCOZS0001#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500e-UNIVERSALK9-M), Version 03.08.06.E RELEASE SOFTWARE (fc4)
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG10
VWARCOZS0001 uptime is 3 days, 12 hours, 18 minutes
Uptime for this control processor is 3 days, 12 hours, 20 minutes
System restarted at 20:11:13 AR Thu Dec 29 2022
System image file is "bootflash:cat4500e-universalk9.SPA.03.08.06.E.152-4.E6.bin"
Jawa Revision 7, Winter Revision 0x0.0x41
Last reload reason: power-on
License Information for 'WS-X45-SUP7L-E'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4506-E (MPC8572) processor (revision 6) with 2097152K bytes of physical memory.
Processor board ID SPE1749009U
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from PowerUp
23 Virtual Ethernet interfaces
224 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
2 Accepted Solutions
balaji.bandi
i followed below steps and works as expected :
Make sure take config backup out of the box
Read the release notes
perform the task in maintenance window
1. Copy the New image to Switch
2. configuration register value 0x2102
3. check the image in both the device :
show bootflash:
show slavebootflash:
4. veryfy the image :
verify bootflash:iosxe.bin
verify slavebootflash:iosxe.bin
5. remove old boot image
no boot system flash bootflash:oldiosxe.bin
6. change the boot variable :
boot system flash bootflash:iox.bin
7. config register
8. verify boot variable
show bootvar (make sure new image in the variable)
9. save config
write memory (give 5min make sure config sync correctly)
10. reload VSS (if you good downtime)
redundancy reload shelf
Issue the redundancy reload peer command to reload the standby supervisor engine and bring the engine back online (with the new version of Cisco IOS XE software).
Conduct a manual switchover to the standby supervisor engine with the redundancy force-switchover command.
Note : check always release notes some commands and sted may vary.
BB
Since you have not mentioned what is the target version you going to.,
If you decided, my point mentioned part of the list :
which will give you direction - is the ROMMON upgrade required or not required? (it will depend on the target version of code you choose to upgrade)
I have pasted the latest cisco recommendation version and release notes : (Upgrading the System Software)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-311xe-4500e.html
BB
balaji.bandi
show bootflash:
7. config register
9. save config
BB
Thank you so much dear for your response.
Dear I have a last questions. Can I upgrade  only imagen XE? or it is also important to install the rommon software? Thank you
BB
