Wacky Routing issue with VLAN
mbj
I have a 3825 router that I have setup with the following:
interface GigabitEthernet0/0
no ip address
ip flow ingress
ip flow egress
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
service-policy output MARK-PCOM-VIDEO
end
interface GigabitEthernet0/0.1
description Baraboo, WI LAN$ETH-LAN$
encapsulation dot1Q 1 native
ip address 10.22.10.7 255.255.0.0
ip helper-address 10.22.10.241
no snmp trap link-status
end
interface GigabitEthernet0/0.172
description Baraboo VLAN 172
encapsulation dot1Q 172
ip address 172.22.1.1 255.255.255.0
end
Its on a trunked port to my 3750 switch. I am new to this compnay and havent changed it over to IP routing on the switch quite yet.
Both Vlans are setup on the 3750 without an SVI. All hosts on VLAN 1 can ping both interfaces without issue.
If I put a host on the 172 VLAN it cannot ping anything on the router. If I put another host on the VLAN they can ping each other. If I put an SVI on switch the 172 VLAN hosts can ping the switch, but still not the router. ONce I put the SVI on the switch, it can no longer ping the  router. I am giving the SVI ip 172.22.1.5/24.
I have verfied with TAC that the trunk is allowing the vlans to the router.
I have been working with TAC. They have asked me to update the code on the switch, but I think they are just punting.
Swith is running:
c3750e-universalk9-mz.122-58.SE2
TAC wants me to go to c3750e-universalk9-tar.122-55.SE5.tar:
Router is running:
c3825-advsecurityk9-mz.124-3i.bin
thoughts?
Also this is my first time posting, so if I left out some info let me know.
23 Replies 23
  On the switchport on the 3560 on g1/0/23  try adding "switchport nonegotiate"  and report back .  It's possible that because the 3750 is a vtp server and is in a different vtp domain or no domain in the  router case  it may keep the trunk from coming up correctly .  This is the problem with hardcoding trunks as long as you have a physical link it will tell you it's trunking when it might not be .  Going to a router you have no choice but to hardcode so there is really no way around that. If this doesnt work I'm out of ideas .
Hi, would it be possible for u to post the show run & show ip route, sh ip arp from the router and show spanning-tree vlan 172 from the switch. Also when u have a host in vlan 172 and when u try to ping the router ip do u see outbound pkts incrementing on g1/0/23. Thx
One more thing Is it possible that any of your hosts might have the same ip as your router. Can u confirm if the mac entry on your host matches the mac of the router.
Thx
Added switchport nonnegotiate, no luck.
Aileron88
So in summary, you're only having issues with tagged frames over a trunk.
Can you please issue a 'show interface g1/0/23 switchport' on the 3750 and a 'sh int g0/0' on the 3825.
Adam
Sho INT GIG0/0
MSA3800#sho int gig0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is BCM1125 Internal MAC, address is 0023.0470.a2d0 (bia 0023.0470.a2d0)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/693/2 (size/max/drops/flushes); Total output drops: 155
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/23/256 (active/max active/max total)
     Reserved Conversations 1/1 (allocated/max allocated)
     Available Bandwidth 250000 kilobits/sec
  5 minute input rate 6033000 bits/sec, 752 packets/sec
  5 minute output rate 2431000 bits/sec, 623 packets/sec
     782071494 packets input, 2240142197 bytes, 0 no buffer
     Received 8562996 broadcasts, 0 runts, 0 giants, 31 throttles
     0 watchdog, 2248415 multicast, 0 pause input
     733199563 packets output, 2585060426 bytes, 0 underruns
     9 output errors, 0 collisions, 6 interface resets
     9 lost carrier, 0 no carrier, 0 pause output
Cisco3750-a#sho int gig1/0/23
GigabitEthernet1/0/23 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0022.bda2.b717 (bia 0022.bda2.b717)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 2/255, rxload 1/255
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 19
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2931000 bits/sec, 879 packets/sec
  5 minute output rate 10467000 bits/sec, 1156 packets/sec
     159496831 packets input, 60740883950 bytes, 0 no buffer
     Received 750524 broadcasts (427195 multicasts)
     0 watchdog, 427195 multicast, 0 pause input
     211681195 packets output, 200393435881 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
mcollaery
Just one little thing - use the button on the front of your stack of 3750s to confirm how they are numbered in their stack 1, 2, 3.
Maybe G1/0/23 isn't actually the port you think it is.
mbj
So I did some layer 1 troubleshooting.....
I of course assumed that logically the Router was plugged directly into our core switch....oops. It turns out the last network engineer plugged the router into a Netgear switch that plugged into the router.
So after fixing this issue...it has been resolved. Wow I cannot believe I didnt look at the wiring.
Aaron
Thanks for posting back with the update. I am very glad that you have solved the issue and have shared the solution with us.
If anyone needs it, this is a very good reminder that in troubleshooting what might appear to be a layer 3 routing problem that we need to be very careful to verify layers 1 and 2.
Now perhaps you can mark this question as answered?
Rick
Rick
