WCCP Caching Problem
mdargin
I had WCCP configured to route all HTTP traffic on my Internal VLAN into a new Blue coat device.
Previously I had a older Blue Coat device that used the same WCCPconfiguration and that worked properly.
The problem is since I cutover to the new Blue Coat the WCCP configuration does not hold.  It will work and then it will stop working.  After it stops working I have to manually place the proxy settings in my laptop go to a website and then I just have to remove the proxy settings and then it works properly for about 24 hours before it breaks.  I have to keep following this process.
Do you have any suggestions? The only change is a different bluecoat device with a different IP address but I kept all the other Blue Coat the same as the oolder one..
pablo.nxh
Level 8
Level 8
I saw this issue a couple of times with a BC and a Cisco WAE; both issues were related to a bug in the cache software.
You can try disabling WCCP on the router/switch side just to clear out the assigned buckets if GRE or TCAM allocations if L2 redirection, re-enable after a minute or so and see if that helps.
What services are you redirecting to the BC? Just web-cache?
__ __
Pablo
